ashpri
How to enable VLAN filtering for existing bridge in CLI
Mon Apr 25, 2022 2:34 pm
So I MAC Telnet to a new device, created bridge1 (vlan filtering not enabled at this stage), added bridge vlans, entered other basic setup.
On the very last step of the setup process, I entered:
add name=bridge1 vlan-filtering=yes
and received the error "failure: already have interface with such name"
How do I enable vlan-filtering for an existing bridge on the CLI?
crosswind
Re: How to enable VLAN filtering for existing bridge in CLI  [SOLVED]
Mon Apr 25, 2022 2:55 pm
"add" will add a new bridge, which isn't what you want since your bridge already exists.
to change the configuration on an existing item, use "set":
/interface/bridge
set 0 vlan-filtering=yes
replace 0 with the appropriate item number, which you can see in "print".
Users browsing this forum: NLH and 31 guests
