eldoncito2019
Use global variable that already exists in another script
Mon Apr 25, 2022 5:42 pm
Guys, I have this global variable in another script and I would like to use it in another script, how would it be?
:global stopRouterRun false
:do {
           :delay 60
} while=(!$stopRouterRun)
EL DONCITO.
Amm0
Re: Use global variable that already exists in another script
Mon Apr 25, 2022 5:58 pm
This is in the docs, https://help.mikrotik.com/docs/display/ ... -Variables:
Every variable, except for built-in RouterOS variables, must be declared before usage by local or global keywords. Undefined variables will be marked as undefined and will result in a compilation error.
So if stopRouterRun in your case was defined and assigned as value like "false" elsewhere. You can just remove the assignment in your code above:
:do {
           :delay 60
Amm0
Mon Apr 25, 2022 6:08 pm
@eldoncito2019, it seems like you're re-inventing the wheel, and posting with a question as your attaching each spoke.
There are few script libraries people have written that have a lot of useful "helper functions". You can search the forum for most scripting needs and someone likely already has written a script that can adapted. There are quite a few on GitHub, like https://github.com/eworm-de/routeros-scripts and https://github.com/merlinthemagic/MTM-R ... -Scripting that may give you ideas, or may be a better place to start than a blank canvas script.
eldoncito2019
Re: Use global variable that already exists in another script  [SOLVED]
Mon Apr 25, 2022 8:03 pm
Thanks for your help Amm0, I already solved my problem
:put $stopRouterRun
:do {
      :delay 60
EL DONCITO
Users browsing this forum: No registered users and 35 guests
