T3chDad
hAP ac² RBD52G-5HacD2HnD-TC Dual Configuration...
Tue Apr 26, 2022 1:11 am
I've got two of these units on the way and doing pre-config research. I'd like to use one unit as the router AND and access point. The second unit would be on another floor some distance away and function strictly as an access point for the same network/WiFi as on the "main" router. Is it a simple as setting up one unit to simply be an AP and the other as both AP and router?
Thank you for your time.
Bob
crosswind
Re: hAP ac² RBD52G-5HacD2HnD-TC Dual Configuration...  [SOLVED]
Tue Apr 26, 2022 5:44 am
if you run an Ethernet cable between the two devices, then yes, that will work fine. as long as the wireless configuration matches (same SSID, WPA key, etc., although frequency can be different) then clients will roam between the two APs automatically.
there are other ways to do it, like using CAPsMAN to manage the access points instead of configuring both of them by hand, but for only two access points i don't think i'd bother with that.
T3chDad
Tue Apr 26, 2022 4:01 pm
Thank you. That's the kind of clue I was looking for.
Users browsing this forum: Bing [Bot], lubomirs, Nullcaller, rolling and 62 guests
