3m4x
Kernel failure: upgrade, netinstall or other?
Tue Apr 26, 2022 4:18 pm
during years I had several times "kernel failure" error on my routerboard. Most of them were rare, once a year.
Every time I had such issue I opened a ticket with Support and got answer: "upgrade your RouterOs".
I can understand this approach but if I have a router that mount a "long"-term release and it doesn't have configuration changed, I suppose it couold work for "long" time without upgrade.
Since new RouterOs version are released every month (or week) it's likely that there's always a newer version that one I've installed so I'm not sure if "upgrade" is a solution or a default answer.
Anyway when you faced with a kernel failure issue how did you do?
Did you upgrade RouterOS?
Did you use Netinstall?
Did you upgrade bootloader?
Or other?
rextended
Re: Kernel failure: upgrade, netinstall or other?
Tue Apr 26, 2022 6:05 pm
The software is written by human beings and it is impossible to test a longer time than is available for the software.
If a problem occurs after months, it is obviously impossible to predict it sooner as it would take months before being tried for a long time.
Send supout.rif to MikroTik Support.
No, because is already on long-term, I update the device after some month long-term is available, and no new bugs come out for what I use the device.
No, only 1st time I receve from our distributor the device.
Obviously, Yes, and also Factory RouterrBOOT when permitted/available
>>>Or other?
I not understand what you mean with this question.
Users browsing this forum: anav, Andrey05, Bing [Bot] and 87 guests
