iotmike
hAP ac with wAP LTE
Tue Apr 26, 2022 7:16 pm
I have an hAP ac internet connection comes from a cablemodem by DHCP.
I want to connect a wAP LTE as a failover connection.
Can someone guide me how to configure hAP and wAP LTE in such a manner to be in the same network and that wAP will still be accessible by Winbox by mac address?
rextended
Re: hAP ac with wAP LTE
Tue Apr 26, 2022 7:22 pm
If both ISP and LTE are connected by DHCP, use this as example for failover.
viewtopic.php?f=13&t=176956&p=868082#p868082
If for example your LTE gateway is 192.168.5.1 you can still reach that IP from internal LAN also if faliover is not active.
if you post both configuration files:
/export file=devicename
remove any sensible data inside before put it on forum, like serial number
you can be helped quickly
anav
Wed Apr 27, 2022 6:45 pm
Well one would connect the wap LTE to an ethernet port on the hapac as your ISP2.
https://help.mikrotik.com/docs/pages/vi ... d=26476608
Read up on paras I & J - viewtopic.php?t=182373
Users browsing this forum: Amazon [Bot], synchro and 32 guests
