f31n
ISP multiple IP over transfer net in one router
Tue Apr 26, 2022 10:38 pm
Hi there,
a client of mine just got from his ISP a configuration for multiple public IP-addresses over a transfer net.
They recommend to use their transfer router so one could just use the transfer IP as gateway. We normally use one mtik as transfer router and the second for the actual routing.
So my idea on this point was to do that in one mtik device Separate, and I failed perfectly.
I tried to find any how to about that in google and in this forum, and failed as well, which lead me to the idea to write a post about it.
Either my networking or mtik skills are just not good enough or you just need a physical router for the transfer network and you cannot do that in one device.
Does someone have any inputs on that?
Sob
Re: ISP multiple IP over transfer net in one router
Wed Apr 27, 2022 12:28 pm
Example of what you have and what exactly you want to do with it would probably work better. You know, addresses, subnets, technical info.
Users browsing this forum: No registered users and 63 guests
