atomicduck
mAP lite power draw?
Tue Apr 26, 2022 11:47 pm
Is there a command that will show voltage and current draw of mAP lite device?
I wonder how much it draws, not to overload USB ports, as they usually can reliably provide much less than than 500mA standard describes.
holvoetn
Re: mAP lite power draw?
Tue Apr 26, 2022 11:52 pm
Unless I missed it, not that I know.
But maybe someone else has found a way...
atomicduck
Tue Apr 26, 2022 11:54 pm
Thanks. Do you maybe happen to have real world info on power draw? Website says 700 mA (3.5W) max..
holvoetn
Tue Apr 26, 2022 11:57 pm
I can use it without any problems with a micro-USB connection, so should be max 500mA since that's what a standard USB port should provide.
The power adapter provided is specified at 1A / 5W max. Might be required sometimes when REALLY taxing the little bugger :lol:
atomicduck
Wed Apr 27, 2022 12:01 am
From experience I know that many devices have problems supplying even 500mA on 5v USB output, especially in long term applications.
holvoetn
Wed Apr 27, 2022 12:04 am
Small edit made w.r.t. power adapter supplied.
atomicduck
Wed Apr 27, 2022 12:18 am
Yes, you are right, I just checked :-)
I bought this one as a toy, and I configured it as a bridge AP so I can dig into wired LANs easily... On it have WEYLAND-YUTANI SSID :D
I am kind of amazed by this thing. I get 40 mbps routinely, and it goes up to 60-70 in ideal conditions.
holvoetn
Wed Apr 27, 2022 12:24 am
That's also what I see.
Is indeed a truly powerful thing for the size and price it has.
bpwl
Re: mAP lite power draw?  [SOLVED]
Wed Apr 27, 2022 11:28 am
0.14A - 0.16A measured when connected to laptop
atomicduck
Wed Apr 27, 2022 11:41 am
Thank you very much! Could you share what was the load / Tx power setting?
I presume this is idling power drain?
bpwl
Wed Apr 27, 2022 12:44 pm
Under load, a bit harder to test.
Was already active as repeater, but no client connected. (so wifi radio was active). And this mAP connects to my 2 VPN hubs via SSTP.
When adding the laptop as client and doing download tests it goes up to 0.26A max (CPU 16%, 20Mbps netto, -60dBm connection), but certainly not most of the time.
Just connecting and streaming one Youtube is 0.14-0.19A (CPU 2%)
Total wifi power is 18dBm according to Winbox information. (ETSI regulation = 20dBm- antenna gain = 18dBm total, 15 dBm/antenna) (18dBm = 63mW= 0,013A @ 5V)
atomicduck
Wed Apr 27, 2022 1:11 pm
So, it is 260mA or 1.3W or under reasonable load, which is about 50% for USB 2.0 standard of max 500 mA. With light load it is 0,8W which is truly amazing.
Swell and thanks again!
bpwl
Wed Apr 27, 2022 2:21 pm
Yep. Getting the CPU load up to steady 90% (Btest-send through SSTP tunnel) it peaks at 0,410A.
30dBm/1W wifi power (not allowed in Europe) would add 0.200A at most. But the radio is 22dBm max as specified by MT. (0.032A versus 0.013A@18dBm or +19mA)
Power consumption is not high with MT AP.
See RB260GSP PoE injection .... (no data load) (SXTsq ac 5, hAP ac2, wAP ac)
atomicduck
Wed Apr 27, 2022 3:25 pm
I actually never checked it myself, but I am surprised re wAP ac reqs. I always counted it as 10-15W AP, but it seems taht realistically it is much lower.
Just checked on one of my PoE switches:
RBcAPL-2nD - 1.4 W
RBcAP-2D - 1.0 W
RBwAPr-2nD - 1.8W
These are idling, and go to 2-3W occasionally, which is still very low. This is on 26.9V.
On another switch at 27.2V, CAP ac show about 4-5W more or less constantly.
chechito
Wed Apr 27, 2022 6:32 pm
some time ago i tested power consumption on hap lite hap mini ahn map lite (i dont documented it) and i did not saw too much changes in power consumption with or without load or heavy wireless traffic traffic or radio enabled or disabled
i have seen map-lite gets much warmer when feeded by poe than feeded by usb
holvoetn
Wed Apr 27, 2022 7:01 pm
Logical.
Additional conversion from higher to lower voltage hence higher heath dissipation.
bpwl
Wed Apr 27, 2022 8:41 pm
mAP Lite powered by RB260GSP PoE
Same condition (repeater + VPN, no client) 65-69mA, 1.5-1.6W, that's double of USB
PS: (If shutdown, power consumption is about the same)
luodichen
Wed Jan 31, 2024 11:10 am
This is exactly what I wanted, thank you very much! ! !
Users browsing this forum: almdandi, gianricci, GoogleOther [Bot], patrikg, Renfrew, uamma and 73 guests
