giulianoz
Hap ac3 Wi-Fi performance
Wed Apr 27, 2022 8:34 am
I will post here because it has been a long time since I used routeros wireless features (around 6.13 or similar8, so I might be missing something basic…
Starting point
* isp cattv modem - hex s - plume access point (managed by the isp)
* brand new hap ac3 connected to the modem (to replace hex and ap
What I did
* update everything to 7.2.1
* export config fro hex s
* resettled the hap with no config
* manually copy and paste the config to the hap
* added the Wi-Fi config to the hap
Issues
“ on hex s I get 320/10 mobs with Speedtest on iPad
* on hap I get 222/6 mbps on the same iPad
Config
add authentication-types=wpa2-psk mode=dynamic-keys name=casa supplicant-identity=MikroTik
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n country=japan disabled=no distance=indoors mode=ap-bridge security-profile=casa \
ssid=casa wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40mhz-XX country=japan disabled=no distance=indoors mode=\
ap-bridge security-profile=casa ssid=casa
Both devices have the same firewall rules (basically allow lan traffic, block everything else), a whopping 6 filters and 1 nat.
Is there something I am missing ?
Giuliano
bpwl
Re: Hap ac3 Wi-Fi performance
Wed Apr 27, 2022 11:13 am
- local test (not involving internet speed variations)
- smart frequency setting. "auto" is unpredictable in channel and performance
- what is settings of ISP modem wifi. (channel, 40 MHz, 80 MHz ?)
- "wifiwave2" drivers in hAP ac3
giulianoz
Wed Apr 27, 2022 12:15 pm
Thanks for the suggestions!
I switched to Wi-Fi wave 2 + fixed frequency and I get 310/10 mbps on 5ghz :)
2.4ghz is a total mess in the building, so probably there is no optimal settings (the max i have got was 90/7)
Thanks again !
anav
Wed Apr 27, 2022 6:05 pm
THat is some slow............
bpwl
Wed Apr 27, 2022 8:59 pm
OP gave 40MHz channel bandwidth as config. Dual stream ....would be (MCS09) 400Mbps-40MHz/2S/SGI interface rate , and data is 310Mbps. Looks good to me.
90 Mbps on 2.4GHz crowded area, is probably on (MCS07) 144Mbps-20MHz/2S/SGI interface rate at best.
UP slow? Down slow? It is the ISP provided speed in what I understand from the hEX S.
Users browsing this forum: GoogleOther [Bot] and 123 guests
