GuntOn
Connect to L2TP/IPSec VPN server from iPhone
Wed Apr 27, 2022 11:14 am
I have running Mikrotik L2TP/IPSec server and I can connect to it from Android without any problems. Is it possible to connect to this server from iPhone? I am a little bit confused because iPhone built in VPN client offers L2TP, IPSec and IKEv2 type tunnels and it does not have option L2TP/IPSec like it is on Android. iPhone 12 running iOS 15.4.1 version.
Thanks!
kevinds
Long time Member
Long time Member
Re: Connect to L2TP/IPSec VPN server from iPhone
Wed May 04, 2022 12:27 am
I don't know for sure, but I sent this to a user, because I have no Apple devices to test/confirm with, and I didn't hear back after..
https://campus.barracuda.com/product/ne ... entication
own3r1138
Long time Member
Long time Member
Wed May 04, 2022 1:41 am
kevinds
Long time Member
Long time Member
Wed May 04, 2022 1:45 am
Thank you..
Seems obvious where to put the password and PSK secret
Will you please also post what it looks like when you tap secret.. iOS' PSK vs x.509 prompts..
own3r1138
Long time Member
Long time Member
Wed May 04, 2022 1:51 am
YVW. thats an ON and OFF option it works with RSA no password. I guess just a handshake.
kevinds
Long time Member
Long time Member
Wed May 04, 2022 2:31 am
So where do you put the IPSec secret?
own3r1138
Long time Member
Long time Member
Wed May 04, 2022 2:34 am
The "secret" refers to PSK.
kevinds
Long time Member
Long time Member
Wed May 04, 2022 2:39 am
But you said,
So now I am very confused..
own3r1138
Long time Member
Long time Member
Wed May 04, 2022 2:41 am
What part is confusing you maybe my English is the part :D
kevinds
Long time Member
Long time Member
Wed May 04, 2022 2:47 am
I asked for a screen shot of what the Secret prompt looks like,
You said it is just On/Off..
So I responded with
You responded with,
So I am confused on where the PSK or x.509 certificate goes if Secret is just on/off...
own3r1138
Long time Member
Long time Member
Wed May 04, 2022 2:53 am
Oh, I see. So there is no certificate option in iOS only PSK but it has SecureID so it uses a certificate "EAP-RSA" to generate a pin.
Users browsing this forum: DanMos79, fxcd, jaclaz, MADM1k3, Majestic-12 [Bot] and 51 guests
