ilium007
Chateau LTE12 turned off all LED's now power LED won't stay on
Thu Apr 28, 2022 5:54 pm
I had set routerOS (7.2.1) to run a script on startup to turn off all LED's.
I now want the LED's to be on including the power LED.
I have enabled with
/system leds settings set all-leds-off=never
but only WIFI, Ethernet and LTE LED's illuminate. The power LED does not turn on.
If I power cycle router the blue power LED does turn on but turns off soon afterwards.
[admin@MikroTik] /system> leds/print
Flags: X - DISABLED; * - DEFAULT
Columns: TYPE, INTERFACE, LEDS
#    TYPE          INTERFACE  LEDS
0 X* modem-signal  lte1       led1
                              led2
                              led3
                              led4
                              led5
settings  add  disable  edit  enable  export  find  print  remove  reset  set
[admin@MikroTik] /system> leds/settings/print
  all-leds-off: never
hecatae
Re: Chateau LTE12 turned off all LED's now power LED won't stay on
Thu Apr 28, 2022 10:06 pm
I would netinstall with default configuration if you cannot get the LEDs working.
holvoetn
Thu Apr 28, 2022 10:34 pm
Which version of ROS are you running ?
There was a fix specifically for LED usage on Audience in 7.2
ilium007
Thu Apr 28, 2022 11:50 pm
Sorry, I should have mentioned that it’s running 7.2.1
rextended
Fri Apr 29, 2022 1:20 am
what is the output of:
/system leds export
(do not post the serial number)
ilium007
Fri Apr 29, 2022 1:35 am
/system leds export
[admin@MikroTik] > /system/leds/export
# dec/30/2021 00:09:26 by RouterOS 7.2.1
# software id = 8DD5-P647
# model = RBD53G-5HacD2HnD
# serial number = xxx
/system leds
set 0 disabled=yes
[admin@MikroTik] >
rextended
Fri Apr 29, 2022 1:39 am
Your soluction, paste this...
/system leds
set 0 disabled=no
ilium007
/system leds
set 0 disabled=no
Thanks, I'll check later.
ilium007
Fri Apr 29, 2022 2:18 am
So I made the change and rebooted, as before I got the power LED on boot but turns off after approx 15s.
# dec/29/2021 23:33:49 by RouterOS 7.2.1
[admin@MikroTik] >
rextended
Fri Apr 29, 2022 2:28 am
Sorry, but I do not have any idea at the moment, and I do not have a chateau to test.
Check the full /export (but do not post it on forum) if some other parameters are "off" on /system routerboard or other places.
ilium007
Fri Apr 29, 2022 6:41 am
I did a factory config reset and manually entered config again and no power LED. Again, it comes on during start and then turns off. Ethernet and WiFi LED's are working.
holvoetn
Fri Apr 29, 2022 6:43 am
Best to file a report to support@mikrotik.com then.
ilium007
Will do
rextended
Fri Apr 29, 2022 10:08 am
until is resetted and not configured the led is on as wanted?
you have scheduled some script to disalbe led at startup?
ilium007
Fri Apr 29, 2022 10:57 am
After a factory reset (and running 7.2.1) the power LED comes on briefly during boot and then turns off. No scripts, nothing. Factory reset.
rextended
Fri Apr 29, 2022 11:00 am
thank you, it was to exclude these possibilities as well
ilium007
All good. I have raised a support request and attached a support.rif file.
hecatae
Mon May 02, 2022 12:56 am
I'm not sure what I'm doing wrong but I can't recreate this on any of my chateau.
ilium007
Mon May 02, 2022 7:13 am
I have factory reset twice and the power LED remains off. It comes on during boot and turns off soon after.
My config:
# may/02/2022 14:09:39 by RouterOS 7.2.1
# serial number = xxxx
add admin-mac=48:8F:5A:11:24:D8 auto-mac=no comment=defconf name=bridge \
    protocol-mode=stp
/interface lte
# SIM not present
set [ find ] allow-roaming=no band="" disabled=yes name=lte1
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk eap-methods="" group-key-update=1h mode=\
    dynamic-keys name=xxxx supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n channel-width=20/40mhz-Ce \
    country=australia disabled=no distance=indoors frequency=auto \
    installation=indoor keepalive-frames=disabled mode=ap-bridge \
    multicast-buffering=disabled multicast-helper=full preamble-mode=long \
    scan-list=2412,2437,2463 security-profile=xxxx ssid=xxxx tx-power=\
    10 tx-power-mode=all-rates-fixed wireless-protocol=802.11 wmm-support=\
    enabled wps-mode=disabled
set [ find default-name=wlan2 ] antenna-gain=2 band=5ghz-a/n/ac \
    channel-width=20/40/80mhz-Ceee country=australia default-forwarding=no \
    disabled=no distance=indoors frequency=auto installation=indoor \
    keepalive-frames=disabled mode=ap-bridge multicast-buffering=disabled \
    multicast-helper=full preamble-mode=long security-profile=xxxx ssid=\
    xxxx tx-power=20 tx-power-mode=all-rates-fixed wireless-protocol=\
    802.11 wmm-support=enabled wps-mode=disabled
/interface wireless nstreme
set wlan1 disable-csma=yes enable-polling=no
add name=default-dhcp ranges=192.168.10.50-192.168.10.254
add address-pool=default-dhcp interface=bridge lease-time=8h name=defconf
/zerotier
set zt1 comment="ZeroTier Central controller - https://my.zerotier.com/" \
    identity="xxxx" name=zt1 \
    port=9993
/zerotier interface
add allow-default=no allow-global=no allow-managed=yes disabled=no instance=\
    zt1 name=zerotier1 network=xxxx
add bridge=bridge comment=defconf interface=wlan2
set discover-interface-list=LAN protocol=""
/ipv6 settings
set accept-redirects=no accept-router-advertisements=no disable-ipv6=yes \
    forward=no
/interface detect-internet
set detect-interface-list=WAN internet-interface-list=WAN lan-interface-list=\
    LAN wan-interface-list=WAN
add address=192.168.10.1/24 interface=bridge network=192.168.10.0
/ip dhcp-client
add interface=ether1 use-peer-dns=no
add address=192.168.10.0/24 dns-server=192.168.10.45 domain=home gateway=\
    192.168.10.1 netmask=24
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add address=192.168.10.1 comment=defconf name=router.home
add action=accept chain=forward comment=zerotier in-interface=zerotier1
add action=accept chain=input in-interface=zerotier1
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ip firewall mangle
add action=set-priority chain=postrouting comment="Set priority for WMM" \
    new-priority=from-dscp-high-3-bits passthrough=yes
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Australia/Sydney
/system leds
set 0 disabled=yes
/system logging
add disabled=yes topics=lte,!raw
/system ntp client
set enabled=yes
/system ntp client servers
add address=au.pool.ntp.org
/system routerboard settings
set auto-upgrade=yes
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system scheduler
add interval=30s name=dhcp2dns on-event=dhcp2dns policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-time=startup
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
add dont-require-permissions=no name=dhcp2dns owner=admin policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":\
    local domains [:toarray \"home\"]\
    \n:local dnsttl \"15m\"\
    \n\
    \n:local magiccomment \"automatic-from-dhcp (magic comment)\"\
    \n:local activehosts [:toarray \"\"]\
    \n\
    \n:foreach lease in [/ip dhcp-server lease find] do={\
    \n  :local hostname [/ip dhcp-server lease get value-name=host-name \$leas\
    e]\
    \n  :local hostaddr [/ip dhcp-server lease get value-name=address \$lease]\
    \n\
    \n  :if ([:len \$hostname] > 0) do={\
    \n    :foreach domain in \$domains do={\
    \n      :local regdomain \"\$hostname.\$domain\"\
    \n      :set activehosts (\$activehosts, \$regdomain)\
    \n\
    \n      :if ([:len [/ip dns static find where name=\$regdomain]] = 0) do={\
    \n        /ip dns static add name=\$regdomain address=\$hostaddr comment=\
    \$magiccomment ttl=\$dnsttl\
    \n      } else={\
    \n        :if ([:len [/ip dns static find where name=\$regdomain comment=\
    \$magiccomment]] = 1) do={\
    \n          /ip dns static set address=\$hostaddr [/ip dns static find nam\
    e=\$regdomain comment=\$magiccomment]\
    \n        }\
    \n      }\
    \n    }\
    \n  }\
    \n}\
    \n\
    \n:foreach dnsentry in [/ip dns static find where comment=\$magiccomment] \
    do={\
    \n  :local hostname [/ip dns static get value-name=name \$dnsentry]\
    \n  :if ([:type [:find \$activehosts \$hostname]] = \"nil\") do={\
    \n    /ip dns static remove \$dnsentry\
    \n  }\
    \n}"
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set filter-interface=zerotier1 filter-stream=yes streaming-enabled=yes \
    streaming-server=192.168.10.249
ilium007
Wed May 04, 2022 1:33 pm
Logged a support ticket with Mikrotik and get the following response:
By checking your supout rif file, the led are disabled, please recheck the configuration and reset/ reinstall the device.
MikroTik support offers assistance if there is a problem or bug with RouterOS or other MikroTik products.
If you require assistance with configuration, we ask you to contact the company from which you did purchase this product:
https://mikrotik.com/buy
If you require premium support, then you can contact our consultants in order to get assistance with network planning and/or configuration:
https://mikrotik.com/consultants
You can also try to ask for help on our user forum:
forum.mikrotik.com
Or you can learn from our software manuals:
https://wiki.mikrotik.com/wiki/Main_Page
https://help.mikrotik.com/docs/
Best regards
So pretty much out of luck with their support. I had already preformed a configuration reset and there was nothing 'disabled'. They took the time to look at the supout file but couldn't tell me where the LED is evidently 'disabled' (it isn't). I performed a RouterOS upgrade to 7.2.3 tonight, wiped configuration and didn't apply the default config so a blank slate.... still no power LED. Its not hardware because it comes on at boot and then turns off.
Reset to default config again and still no LED. The 'dark-mode' script is default config. I tried disabling the `/system routerboard mode-button` and rebooting but it made no difference.
❯ ssh admin@192.168.88.1
Warning: Permanently added '192.168.88.1' (RSA) to the list of known hosts.
admin@192.168.88.1's password:
  MMM      MMM       KKK                          TTTTTTTTTTT      KKK
  MMMM    MMMM       KKK                          TTTTTTTTTTT      KKK
  MMM MMMM MMM  III  KKK  KKK  RRRRRR     OOOOOO      TTT     III  KKK  KKK
  MMM  MM  MMM  III  KKKKK     RRR  RRR  OOO  OOO     TTT     III  KKKKK
  MMM      MMM  III  KKK KKK   RRRRRR    OOO  OOO     TTT     III  KKK KKK
  MMM      MMM  III  KKK  KKK  RRR  RRR   OOOOOO      TTT     III  KKK  KKK
  MikroTik RouterOS 7.2.3 (c) 1999-2022       https://www.mikrotik.com/
Press F1 for help
The following default configuration has been installed on your router:
Welcome to RouterOS!
   1) Set a strong router password in the System > Users menu
   2) Upgrade the software in the System > Packages menu
   3) Enable firewall on untrusted networks
   4) Set your country name to observe wireless regulations
   --------------------------------------------------------------------------        TE CPE Router with wireless AP:
    IP address 192.168.88.1/24 is set on bridge (LAN port)
    DHCP Server: enabled;
    DNS: enabled;
wlan1 Configuration:
    mode:                ap-bridge;
    band:                2ghz-b/g/n;
    tx-chains:           0;1;
    rx-chains:           0;1;
    installation:        indoor;
    wpa2:      no;
    ht-extension:        20/40mhz-XX;
wlan2 Configuration:
    mode:                ap-bridge;
    band:                5ghz-a/n/ac;
    tx-chains:           0;1;
    rx-chains:           0;1;
    wpa2:      no;
    ht-extension:        20/40/80mhz-XXXX;
WAN (gateway) Configuration:
    gateway:  lte1 ;
    ip4 firewall:  enabled;
    ip6 firewall:  enabled;
    NAT:   enabled;
Login
    admin user protected by password
You can type "v" to see the exact commands that are used to add and remove
this default configuration, or you can view them later with
'/system default-configuration print' command.
To remove this default configuration type "r" or hit any other key to continue.
If you are connected using the above IP and you remove it, you will be disconnected.
Confirming configuration
jan/02/1970 00:00:17 system,error,critical router rebooted without proper shutdown, probably power outage
jan/02/1970 00:00:18 system,error,critical router rebooted without proper shutdown, probably power outage
jan/02/1970 00:01:06 system,error,critical login failure for user  from 38:C9:86:36:87:04 via winbox
jan/02/1970 00:01:07 system,error,critical login failure for user admin from 192.168.88.2 via winbox
jan/02/1970 00:01:09 system,error,critical login failure for user  from 192.168.88.2 via winbox
[admin@MikroTik] >
[admin@MikroTik] > export show-sensitive
# jan/02/1970 00:05:32 by RouterOS 7.2.3
# serial number = C8CA0CB0B626
/interface lte
# SIM not present
set [ find ] allow-roaming=no band="" name=lte1
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-1124DD wireless-protocol=\
    802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-1124DE \
/ip hotspot profile
add address-pool=default-dhcp interface=bridge name=defconf
add comment=defconf interface=lte1 list=WAN
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r\
    \n   } else={\r\
    \n   }\r\
    \n "
/tool mac-server
[admin@MikroTik] >
Is there way to wipe NVRAM completely and recovery from netinstall? Not sure if there is some setting that is not being wiped when performing the `/system/reset-configuration no-defaults=yes`
The power led comes on at boot and then turns off. Interestingly that factory dark-mode script will turn off the lte, ethernet and wifi LED's and turn them back on again, it has no effect on the power led.
ilium007
Thu May 05, 2022 1:27 pm
So I persisted with Mikrotik support and only then did the same person who told me yesterday that I needed to hire a consultant tells me that the power LED does not remain on unless the LTE interface is up. As I no longer use this router with a SIM card and LTE this is the reason the power LED is not on.
Support aside...... why is the devices' power LED is dependent on a SIM card and LTE interface being up!
hecatae
Thu May 05, 2022 5:12 pm
/system leds
# using RSRP, modem-signal-threshold ignored
set 0 disabled=no interface=lte1 leds=led1,led2,led3,led4,led5 modem-signal-threshold=-91 type=modem-signal
That's all I see on an export verbose
Users browsing this forum: No registered users and 43 guests
