ciko
high "ssl" CPU usage on v7.21
Sat Apr 30, 2022 1:47 am
Hi All!
I am really happy with how v7 turned out for me. Migration was painless overall and apart from a generally slightly higher cpu usage I have no negative impact.
What i have been noticing however on my RB4011iGS+ on 7.21 (and also on previous 7 versions) is that i get a quite significant (30+%) CPU usage out of the process "SSL". Can anybody explain what it is and what I should have a look at in order to reduce this? The CPU usage seems not to be dependent on load or VPNs as i tried turning them off as well.
Thanks + best regards
Michael
[admin@MikroTik] /tool> profile duration=10s cpu=all
Columns: NAME, CPU, USAGE
NAME          CPU  USAGE
dns             0  0.5%
networking      0  0%
management      0  0%
ssl             0  33.5%
cpu0               34%
ethernet        1  1%
dns             1  0%
firewall        1  0%
networking      1  0.5%
management      1  0%
ssl             1  0%
bridging        1  0%
unclassified    1  0.5%
cpu1               2%
ethernet        2  0%
firewall        2  0%
networking      2  0.5%
winbox          2  0%
management      2  0%
routing         2  0%
ssl             2  3.5%
unclassified    2  0%
cpu2               4%
ethernet        3  0.5%
networking      3  0%
management      3  1.5%
routing         3  0%
ssl             3  0%
cpu3               2%
tangent
Re: high "ssl" CPU usage on v7.21  [SOLVED]
Sat Apr 30, 2022 5:37 am
OpenVPN or SSTP would be my guess. Show your configuration.
ciko
Wed May 18, 2022 10:53 pm
Hi!
SSTP was the right guess. Although nothing was actually using it, I had a HA-Proxy instance in front of it having check and check-ssl options enabled. That caused the entire load on the ssl process. After removing that the ssl process load is down to 0
Thanks again
best regards
Michael
Users browsing this forum: No registered users and 20 guests
