shlom170
Configure router interface as a switchport
Sat Apr 30, 2022 9:59 am
Hi everyone and sorry for my english.
I have the ccr1009-7g-1c-1s+.
I Have already configured one port with subinterfaces and each of them belongs to a different vlan (so far so good).
Now I want to configure another port that will work as Switchport and it will be associated with one of the existing subinterfaces Vlan.
For example, if I connect a printer to this port it will be associated with one of the Vlans (of the same Subinterface) and it will get a DHCP address from this VLAN.
Hope I was clear, I'm sure I could have explained it more simply.
Thank you
zarianu
Re: Configure router interface as a switchport
Sat Apr 30, 2022 11:04 am
If I got your requirements right - you need to create bridge interface and add one of the subinterfaces (VLAN interface in terms of MT) and physical ethernet port to it.
HTH
Zacharias
Sat Apr 30, 2022 11:46 am
Please draw a network diagram of the desired network topology and how it should work.
Also can you export the VLAN configuration you already have configured ?
anav
Sat Apr 30, 2022 5:13 pm
1. Network diagram,and ensure you detail what type of device each port is connecting to [ a dumb device, like a PC or printer, or a smart device (that can read vlan tags), such as a smart switch or smart AP.]
2. Config
(just ensure no public IPs or public IP gateways are shown)
3. Read this as background...... and on Post #2, look at the Router example config!
viewtopic.php?t=143620
Users browsing this forum: Google [Bot], kormenator and 153 guests
