diamuxin
IKEv2 Server roadwarrior + Let's Encrypt + StrongSwan
Sat Apr 30, 2022 12:07 pm
Hello folks!
I am trying to create a "road warrior" type IKEv2-IPSec connection between a MikroTik router as a server and an Android mobile as a client. Instead of using self-signed certificates, I want to use a Let's Encrypt certificate.
I have successfully directly generated a free certificate from Let's Encrypt using the command:
/certificate
enable-ssl-certificate
This certificate is created on the same Mikrotik DNS Name (xxxxxxxxxxxx.sn.mynetname.net) with an expiration of 3 months, auto-renewable.
This is my configuration of the server part (MT):
/ip ipsec mode-config
add address-pool=pool-vpn address-prefix-length=32 name=ike2-conf-road-warrior split-include=0.0.0.0/0
/ip ipsec policy group
add name=ike2-template-group
/ip ipsec profile
set [ find default=yes ] enc-algorithm=aes-256,aes-128,3des hash-algorithm=sha256
add dh-group=modp2048,modp1536,modp1024 enc-algorithm=aes-256,aes-192,aes-128 hash-algorithm=sha256 name=ike2-profile
/ip ipsec peer
add exchange-mode=ike2 name=ike2-peer passive=yes profile=ike2-profile send-initial-contact=no
/ip ipsec proposal
add auth-algorithms=sha512,sha256,sha1 enc-algorithms=\
    aes-256-cbc,aes-256-ctr,aes-256-gcm,aes-192-ctr,aes-192-gcm,aes-128-cbc,aes-128-ctr,aes-128-gcm lifetime=8h name=\
    ike2-proposal pfs-group=none
/ip ipsec identity
add auth-method=digital-signature certificate=letsencrypt-autogen_2022-04-29T15:54:10Z comment=mobile generate-policy=\
    port-strict mode-config=ike2-conf-road-warrior peer=ike2-peer policy-template-group=ike2-template-group
/ip ipsec policy
add comment=road-warrior dst-address=192.168.68.0/24 group=ike2-template-group proposal=ike2-proposal src-address=0.0.0.0/0 \
    template=yes
And the configuration of the client part (StrongSwan Android)
The problem is that I don't understand how to configure StrongSwan since it only generates a certificate on the server side and does not follow. Do I have to install the same certificate on Android? What type of VPN should I select?
Any help please?
BR.
own3r1138
Long time Member
Long time Member
Re: IKEv2 Server roadwarrior + Let's Encrypt + StrongSwan
Sat Apr 30, 2022 8:13 pm
I think you can not use the let's encrypt certificate with your current AUTH method. because if you are going to use a certificate for AUTH then you have to use a specific remote/client certificate at the user end and this is not possible as you can not generate or sign a client certificate with a free certificate like let's encrypt.
so you have two options.
Firstly,
forget about Let encrypt and do a self sing cert for your IKEv2 then you have to import the CA and remote Cert.
secondly,
change your Authe method and use EAP/Radius then you can use the let's encrypt certificate although you have to set the full certificate chain as certificates in your IPsec identity.
for the android devices, the first option is IKEv2 certificate and the second one is IKEv2 EAP(username/password)
diamuxin
Sun May 01, 2022 8:04 pm
secondly,
Hi, thank you for you answer.
For the second option, could you give me an example on how to configure the Identity? It would be something like this?
I understand that the EAP/Radius must create a Radius server (until now I had none created), would it be something like this?
Would the configuration in the Android client be correct?
Thanks and BR.
own3r1138
Long time Member
Long time Member
Sun May 01, 2022 9:36 pm
could you give me an example of how to configure the Identity? It would be something like this?
You should check this link - official Road Warrior setup
https://help.mikrotik.com/docs/display/ ... outerOSv7)
Let's Encrypt Chain of Trust
https://letsencrypt.org/certificates/
Firewall
/ip/firewall/address-list
add address="Router Public IP/Router LH/LP IP" list=RAS
/ip/firewall/filter
add action=accept chain=input comment=Radius dst-port=1812,1813,3799 protocol=udp src-address-list=RAS
Address attribute should be the same as what you allowed in the firewall rule.
diamuxin
Sun May 01, 2022 11:19 pm
Thanks for your help. It is very interesting.
I already have the root and intermediate certificates installed:
Is the IP address 10.10.10.1 on the Radius Server the same IP as the Mikrotik router (such as IP 192.168.88.1) ?
I don't quite understand this rule:
Is it the public (WAN) IP address?
In that case, do I have to enter the address manually or can it be obtained with mikotik's DDNS?
BR.
own3r1138
Long time Member
Long time Member
Sun May 01, 2022 11:50 pm
You are very welcome.
Thats a private IP like your 88.1 no difference.
In that case, do I have to enter the address manually or can it be obtained with Mikrotik's DDNS?
as you host both sides of the RADIUS locally there is no need to use your public IP. You can use 192.168.88.1 or 127.0.0.1
add address=192.168.88.1 list=RAS
or
add address=127.0.0.1 list=RAS
diamuxin
Mon May 02, 2022 10:59 pm
I'm trying to get it to work with StrongSwan (Android) and it doesn't connect, in the MT Log it informs me: "can't get private key"
StrongSwan log:
May  2 20:18:28 00[DMN] Starting IKE service (strongSwan 5.9.3rc1, Android 12 - SKQ1.211006.001 release-keys/2022-02-01, M2007J17G - Xiaomi/gauguin/Xiaomi, Linux 4.19.113-perf-gf734a3967cc5, aarch64)
May  2 20:18:28 00[LIB] loaded plugins: androidbridge charon android-log openssl fips-prf random nonce pubkey chapoly curve25519 pkcs1 pkcs8 pem xcbc hmac socket-default revocation eap-identity eap-mschapv2 eap-md5 eap-gtc eap-tls x509
May  2 20:18:28 00[JOB] spawning 16 worker threads
May  2 20:18:28 07[IKE] initiating IKE_SA android[4] to 86.XXX.XXX.54
May  2 20:18:28 07[ENC] generating IKE_SA_INIT request 0 [ SA KE No N(NATD_S_IP) N(NATD_D_IP) N(FRAG_SUP) N(HASH_ALG) N(REDIR_SUP) ]
May  2 20:18:28 07[NET] sending packet: from 10.68.20.214[38542] to 86.XXX.XXX.54[500] (716 bytes)
May  2 20:18:28 08[NET] received packet: from 86.XXX.XXX.54[500] to 10.68.20.214[38542] (38 bytes)
May  2 20:18:28 08[ENC] parsed IKE_SA_INIT response 0 [ N(INVAL_KE) ]
May  2 20:18:28 08[IKE] peer didn't accept DH group ECP_256, it requested MODP_2048
May  2 20:18:28 08[IKE] initiating IKE_SA android[4] to 86.XXX.XXX.54
May  2 20:18:28 08[ENC] generating IKE_SA_INIT request 0 [ SA KE No N(NATD_S_IP) N(NATD_D_IP) N(FRAG_SUP) N(HASH_ALG) N(REDIR_SUP) ]
May  2 20:18:28 08[NET] sending packet: from 10.68.20.214[38542] to 86.XXX.XXX.54[500] (908 bytes)
May  2 20:18:28 11[NET] received packet: from 86.XXX.XXX.54[500] to 10.68.20.214[38542] (437 bytes)
May  2 20:18:28 11[ENC] parsed IKE_SA_INIT response 0 [ SA KE No N(NATD_S_IP) N(NATD_D_IP) N(FRAG_SUP) CERTREQ ]
May  2 20:18:28 11[CFG] selected proposal: IKE:AES_CBC_256/HMAC_SHA2_256_128/PRF_HMAC_SHA2_256/MODP_2048
May  2 20:18:28 11[IKE] local host is behind NAT, sending keep alives
May  2 20:18:28 11[IKE] sending cert request for "C=US, O=Internet Security Research Group, CN=ISRG Root X1"
May  2 20:18:28 11[IKE] establishing CHILD_SA android{4}
May  2 20:18:28 11[ENC] generating IKE_AUTH request 1 [ IDi N(INIT_CONTACT) CERTREQ CPRQ(ADDR ADDR6 DNS DNS6) N(ESP_TFC_PAD_N) SA TSi TSr N(MOBIKE_SUP) N(NO_ADD_ADDR) N(EAP_ONLY) N(MSG_ID_SYN_SUP) ]
May  2 20:18:28 11[NET] sending packet: from 10.68.20.214[48528] to 86.XXX.XXX.54[4500] (448 bytes)
May  2 20:18:28 12[NET] received packet: from 86.XXX.XXX.54[4500] to 10.68.20.214[48528] (240 bytes)
May  2 20:18:28 12[ENC] parsed IKE_AUTH response 1 [ N(AUTH_FAILED) ]
May  2 20:18:28 12[IKE] received AUTHENTICATION_FAILED notify error
Do you know where the problem can come from?
BR.
own3r1138
Long time Member
Long time Member
Mon May 02, 2022 11:05 pm
diamuxin
Mon May 02, 2022 11:52 pm
Yes, I had seen it, I have modified it in MT but it still fails.
BR.
own3r1138
Long time Member
Long time Member
Tue May 03, 2022 2:13 am
https://wiki.mikrotik.com/wiki/Manual:I ... entication
Android (strongSwan) client configuration
ECP256
Users browsing this forum: BoraHorza, holla29, jaclaz, JeffreyAxori, Majestic-12 [Bot], markinhusxp and 205 guests
