texmeshtexas
Download list from https similar to team-cymru
Sun May 01, 2022 4:17 am
I found this script and haven been using it successfully to download bogon lists.
However, I'm trying to use the same script to download a different list from Talos that is offered in same exact format but there is something about it that the fetch command does not like.
the list is located here https://www.talosintelligence.com/docum ... -blacklist
anyone know why fetch is happy with https://www.team-cymru.org/Services/Bog ... s-ipv4.txt but not https://www.talosintelligence.com/docum ... -blacklist?
# Automatically add BOGONs to your firewall's address lists.
# Only works with 6.43 and up.
# Please do not fetch more often than the listed update interval, for the
# lists that are updated only as IANA allocations change, please do not fetch
# more than once per day.
# by Phillip Stromberg
# 2018-11-07
# uses team-cymru.org BOGON lists
:global content;
:local url;
:local addressListName;
:set addressListName "BogonsFullIPv4"
####################### UNCOMMENT THE URL YOU NEED: #######################
### This is the list of bit notation bogons, aggregated, in text format.
### Updated as IANA allocations and special prefix reservations are made.
# :set url "https://www.team-cymru.org/Services/Bog ... bn-agg.txt"
### The traditional bogon prefixes, plus prefixes that have been allocated to RIRs
### but not yet assigned by those RIRs to ISPs, end-users, etc.
### Updated every four hours.
#:set url "https://www.team-cymru.org/Services/Bog ... s-ipv4.txt"
:set url "https://www.talosintelligence.com/docum ... -blacklist"
:local result [/tool fetch url=$url as-value output=user];
:if ($result->"status" = "finished") do={
:set content ($result->"data");
:global contentLen [ :len $content ];
:global lineEnd 0;
:global line "";
:global lastEnd -1;
/ip firewall address-list remove [find list=$addressListName];
:do {
:set lineEnd [:find $content "\n" $lastEnd ];
:set line [:pick $content $lastEnd $lineEnd];
:set lastEnd ( $lineEnd + 1 );
:if ( [:pick $line 0] = "#" ) do={
} else={
# :put $line;
/ip firewall address-list add address=$line list=$addressListName;
} while ($lineEnd < $contentLen - 2)
msatter
Re: Download list from https similar to team-cymru
Sun May 01, 2022 12:48 pm
Maybe because of this:
texmeshtexas
Sun May 01, 2022 5:31 pm
works from my web browser just fine.
I think it has to do with the initial site has 301/302 redirects to https://snort.org/downloads/ip-block-list
which then redirects to https://snort-org-site.s3.amazonaws.com ... 2489a7eb44
even putting that last one in my web browser works fine the first time.
I think the Signature is dynamic
Then I tried this
https://snort-org-site.s3.amazonaws.com ... filter.blf
Fetch no longer gets an error but returns nothing. but his works consistently in my web browser.
msatter
Sun May 01, 2022 5:46 pm
I can't help any further because can't open stuff that is on AmazonAWS . Look at my signature.
texmeshtexas
Sun May 01, 2022 6:15 pm
ok. thanks for offering.
rextended
Sun May 01, 2022 6:56 pm
Fetch do not support redirect.
Testing https://snort.org/downloads/ip-block-list on script based on
viewtopic.php?f=2&t=178355&p=878643#p878643
this is the result:
terminal code
Waiting the end of process for file testfetch.txt to be ready, max 20 seconds...
waiting... 1
waiting... 2
Done. Elapsed Seconds: 2
Result of Fetch:
  status: connecting
  status: failed
failure: closing connection: <302 Found "https://snort-org-site.s3.....34c73e4c5a"> 104.18.139.9:443 (4)
when the error is 302, using :pick and :find inside the script over the variable $filecontent you can read the redirected URL
Removing all debug info on the code:
/file remove [find where name="testfetch.txt"]
    :local jobid [:execute file=testfetch.txt script="/tool fetch url=\"https://snort.org/downloads/ip-block-list\""]
    :local Gltesec 0
    :while (([:len [/sys script job find where .id=$jobid]] = 1) && ($Gltesec < 20)) do={
        :set Gltesec ($Gltesec + 1)
        :delay 1s
    :if ([:len [/file find where name="testfetch.txt"]] = 1) do={
        :local filecontent [/file get [/file find where name="testfetch.txt"] contents]
        :put [:pick $filecontent ([:find $filecontent "<302 Found \"" -1] + 12 ) [:find $filecontent "\"> " -1]]
you obtain the correct URL: (all on same line, but formatted with enter at the "?" and "&" for readability on forum)
terminal code
?X-Amz-Algorithm=AWS4-HMAC-SHA256
&X-Amz-Credential=AKIAU7AK5ITMFGQS4MSV%2F20220501%2Fus-east-1%2Fs3%2Faws4_request
&X-Amz-Date=20220501T154240Z&X-Amz-Expires=3600
&X-Amz-SignedHeaders=host
&X-Amz-Signature=fba15d0995a1c49f48588ce7b34a3178495769e5391e28c6a8e00f8a0fcd7dc9
if the URL is not updated on this way, using only ".blf" link, you obtain
html code
<Error>
<Code>AccessDenied</Code>
<Message>Access Denied</Message>
<RequestId>G7395GJY4J7KEGQF</RequestId>
<HostId>
ml9x/fMPByX01HgzN1qYz3wNIHpcrArojvm4KPHdmSAlq/taVatI4ISPwWKt3fn0FEmxOIjAYP0=
</HostId>
</Error>
texmeshtexas
Re: Download list from https similar to team-cymru  [SOLVED]
Sun May 01, 2022 7:33 pm
Ok. so I took that approach and generated a variable called newurl and tried to use that in the fetch to download the list
in the end I get this
https://snort-org-site.s3.amazonaws.com ... S4-HMAC-SH
A256&X-Amz-Credential=AKIAU7AK5ITMFGQS4MSV%2F20220501%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20220501T163250Z&X-Amz-Expires=3600&X-
Amz-SignedHeaders=host&X-Amz-Signature=736deb7481413a0e32106687f80271b6ca53dfbefe88972f7827d0bb972e4235
failure: invalid URL protocol
    :local Gltesec 0
        :delay 1s
       :local newurl [:pick $filecontent ([:find $filecontent "<302 Found \"" -1] + 12 ) [:find $filecontent "\"> " -1]];
   :log info "newurl=$newurl";
rextended
Sun May 01, 2022 9:13 pm
Using your link I have different error, why? ROS version?
terminal code
  status: failed
failure: cannot open file
texmeshtexas
Mon May 02, 2022 1:35 am
using 6.49.6 final full code
# Automatically add Talos Blacklist to firewall address list
# 2018-11-07
    :global Tcontent;
    :local starturl;
    :set addressListName "Talos"
 #   :set starturl "https://www.talosintelligence.com/documents/ip-blacklist"
    :set starturl "https://snort.org/downloads/ip-block-list"
 #    :set starturl "https://snort-org-site.s3.amazonaws.com/production/document_files/files/000/014/565/original/ip_filter.blf"
### code to process web redirect by rextended on MT forum ###
    :local jobid [:execute file=testfetch.txt script="/tool fetch url=\"$starturl\""]
    :local Gltesec 0
        :delay 1s
    :global Tresult [/tool fetch url=$newurl as-value output=user];
    :if ($Tresult->"status" = "finished") do={
        :set Tcontent ($Tresult->"data");
    :global TcontentLen [ :len $Tcontent ];
    :global lineEnd 0;
    :global line "";
    :global lastEnd -1;
    :do {
        :set lineEnd [:find $Tcontent "\n" $lastEnd ];
        :set line [:pick $Tcontent $lastEnd $lineEnd];
        :if ( [:pick $line 0] = "data" ) do={
        } else={
            # :put $line;
texmeshtexas
Mon May 02, 2022 1:42 am
Actually, I changed the :local newurl to :global newurl and script is working and downloading the list now!!!
Thanks for the help!
rextended
Mon May 02, 2022 2:50 am
Just a reformatted style:
# 2018-11-07
    :global Tcontent
    :local  starturl
    :local  addressListName "Talos"
        :local Gltesec 0
            :delay 1s
    :global TcontentLen [:len $Tcontent]
    :global lineEnd     0
    :global line        ""
    :global lastEnd     -1
    remove [find where list=$addressListName]
    :do {
        :set lineEnd [:find $Tcontent "\n" $lastEnd]
        :set lastEnd ($lineEnd + 1)
        :if ([:pick $line 0] != "data") do={
            # :put $line
Users browsing this forum: No registered users and 19 guests
