ilium007
ZeroTier 'interfaces'
Sun May 01, 2022 2:22 pm
I'm a bit stuck here. I don't know what 'interfaces' I should be selecting here:
If I select anything other than 'all' the connection gets stuck on "REQUESTING_CONFIGURATION"
The Mikrotik documentation page (https://help.mikrotik.com/docs/display/ROS/ZeroTier) isn't all that helpful:
anav
Re: ZeroTier 'interfaces'
Sun May 01, 2022 4:07 pm
Best article on the subject.........
viewtopic.php?t=183424
ilium007
Mon May 02, 2022 7:07 am
I'll go through it again, thanks.
ilium007
Mon May 02, 2022 3:56 pm
I've re-read this tonight. It doesn't really provide any more info. It says that the interface selection is just for specifying interfaces the zero tier 'may' use.
Amm0
Mon May 02, 2022 6:05 pm
The ZT Interface selector on the instance controls where it will establish tunnels to other ZT peers/etc. May not 100% accurate but essentially "instance" (e.g. "zt1") is what establishes ZT tunnels, the get manifests as ZT network interface ("zeroteir1").
By default ZT will attempt to establish a connection on "all" interface, since you may have peers on the LAN and WAN at same time. But if you pick an interface[/list], then it will ONLY use that to establish tunnels.
If you goal is remote access to the router itself, then could use "WAN" (or your uplink interface). Now if the interface[/list] has no direct internet access, like "LAN", it might be a problem since it might be restricted from reaching the root/planets.
I've just left it "all", but I can see use cases ZT network or security model where you would rather not have all the ZT stuff going doing some interface.
You can try different settings, and the effects can be seen in the "Peer" view. You may have to click on a particular peer to see the full list of "Paths" - winbox's list only shows the first one.
anav
Mon May 02, 2022 7:58 pm
@Amm0, please consider adding too, or modifying your article if you think appropriate to cover off the OPs concerns (assuming they are legitimate requirements that you could see others needing).
ilium007
Tue May 03, 2022 12:23 am
Thanks @Amm0 - what led me to your post was that when I set ‘interface’ to anything but ‘all’ (I had wanted it set to ‘WAN’) ZeroTier on routerOS would hang at REQUESTING_CONFIGURATION.
Amm0
Tue May 03, 2022 12:48 am
You know it's entirely possible there are bug/limitations. And actually you understand do how it should work :). Mikrotik isn't quick with support tickets, but if created one with a supout.rif, it worth to see what they say.
ilium007
Tue May 03, 2022 3:37 am
Thanks - I’ll raise a ticket.
ilium007
Wed May 04, 2022 1:25 pm
Upgraded to RouterOS 7.2.3 and I can now get a connection specifying the 'WAN' interface list.
holvoetn
Wed May 04, 2022 1:26 pm
Interesting ... what version were you coming from ?
ilium007
Wed May 04, 2022 1:32 pm
7.2.1
Users browsing this forum: bcmdevtl, lurker888 and 87 guests
