gsmphoenix
Open VPN
Sun May 01, 2022 5:43 pm
Hi all
I just need help with accessing multiple subnet range over OpenVPN.
1. My OpenVPN can connect with problem.
2. I have to subnets 192.168.0.0/24 & 192.168.3.1/24
I need client to be able to reach both ip range once connect
please help
pe1chl
Re: Open VPN
Sun May 01, 2022 6:38 pm
The MikroTik OpenVPN cannot do that.
gsmphoenix
Re: Open VPN
Sun May 01, 2022 7:19 pm
cant these be over comed via routing ?
pe1chl
Re: Open VPN
Sun May 01, 2022 7:23 pm
Sure but you would have to do that yourself, by adding a route on the client every time you connect.
Normally OpenVPN can push routes to clients, and RouterOS cannot do that.
Sob
Re: Open VPN
Sun May 01, 2022 7:25 pm
You can put routes in client's config file:
route 192.168.0.0 255.255.255.0
route 192.168.3.0 255.255.255.0
own3r1138
Long time Member
Long time Member
Re: Open VPN
Sun May 01, 2022 9:56 pm
redirect-gateway def1
Users browsing this forum: No registered users and 87 guests
