butzmann
Unable to update from 6.xx (stable or LT) to 7.2.1
Mon May 02, 2022 9:38 am
What am I doing wrong? Tried Upgrading from package list, tried uploading the upgrade file.
mkx
Re: Unable to update from 6.xx (stable or LT) to 7.2.1
Mon May 02, 2022 1:44 pm
After device reboots trying to upgrade just to remain on the same version, what does log say about it? Or you didn't get that far? Explain your trouble in some more details ...
holvoetn
Mon May 02, 2022 5:14 pm
Details such as:
- which device
- coming from which ROS6 version
- how did you try to upgrade
Little details like that.
butzmann
Mon May 02, 2022 11:04 pm
HAP AC2, ROS 6.49.6 (and 6.48.6), system consists of individual packages.
Tried upgrading from Packages and uploading an upgrade image.
Same with 7.2.2
butzmann
Mon May 02, 2022 11:41 pm
Ok, nice. Uninstalled every package excluding system and security, rebooted, then update worked.
I had a HEX S with a mix of packages, it updated to 7.1.5 without a problem.
npeca75
Thu May 12, 2022 9:04 pm
Same with 7.2.2
In my case, it was enough to uninstall Wireless and PPP packages
HAP ac2 6.49.6 -> 7.2.3
so if your remote device could live without them, it is possible to do remote update
Users browsing this forum: No registered users and 29 guests
