nagylzs
send_pubkey_test: no mutual signature algorithm
Mon May 02, 2022 5:03 pm
Hello, I just upgraded my OS from Ubuntu 20.04 LTS to 22.04 LTS. Now I cannot login to my ROS 7.2.1 devices using an ssh agent. If I try this from any 20.04 OS (or Windows 10 + Putty), then it works. I have tried to connect with "-vvvv" option and this is what I see in the debug log:
debug1: Offering public key: /home/my_user/.ssh/id_rsa RSA SHA256:2******************************Y agent
debug1: send_pubkey_test: no mutual signature algorithm
What is causing this problem, and how can I fix it?
mkx
Re: send_pubkey_test: no mutual signature algorithm
Mon May 02, 2022 8:22 pm
Newer linux distributions are depreciating some older host key and key exchange algorithms. They are still supported by ssh clients, but disabled by default. You can enable them by adding this to ${HOME}/.ssh/config (create file if it doesn't exist already):
host <router name or IP address>
        KexAlgorithms +diffie-hellman-group1-sha1
        HostKeyAlgorithms +ssh-dss
And keep your RSA key handy, ROS ssh (still) doesn't support newer ecdsa and ed25519 key types.
nagylzs
Wed May 04, 2022 10:47 am
Thank you
nagylzs
Mon May 09, 2022 1:06 pm
Added this into ~/.ssh/config
host r01.eger.magnet
    hostname r01.eger.magnet
But I still see this:
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Offering public key: /home/user/.ssh/id_rsa RSA SHA256:2****************************Y agent
Ssh client is on Ubuntu 22.04 LTS, package versions:
* libssh-4/jammy,now 0.9.6-2build1
* libssh-gcrypt-4/jammy,now 0.9.6-2build1
* libssh2-1/jammy,now 1.10.0-3
* openssh-client/jammy,now 1:8.9p1-3
* ssh-import-id/jammy,jammy,now 5.11-0ubuntu1
eworm
Re: send_pubkey_test: no mutual signature algorithm  [SOLVED]
Mon May 09, 2022 6:04 pm
Ignore the options above... What you need is:
PubkeyAcceptedAlgorithms +ssh-rsa
mkx
Mon May 09, 2022 6:08 pm
Gosh ... this is a new one. A thing to remember.
eworm
Mon May 09, 2022 6:10 pm
And please complain to support...
The earlier we may have support for ed25519 keys. 😜
nagylzs
Thu May 12, 2022 10:48 am
Thanks, it works!
This is all I needed
eworm
Thu May 12, 2022 5:08 pm
Just the last line should be sufficient. The others enable legacy things you do not want.
AnrDaemon
Tue May 31, 2022 3:52 pm
Thanks, that worked quite well.
Match host 192.168.1.1,vpn.darkdragon.lan
ej2pi
Mon Jul 11, 2022 4:47 am
Just wanted to say thank you!! This saved me a considerable amount of time.
TerminalAddict
Wed Aug 24, 2022 11:44 am
not working for me after updating to jammy
Host gulp
        Hostname gulp.bach.redacted.com
        Port 22
        User paul
mt99
Sun Sep 18, 2022 7:19 am
In my case, a new Ubuntu 22.04 server I migrated to wouldn't use the identity file even though I was using the proper syntax. The -vv switch argument on the SSH command showed that the signature algorithm wasn't being accepted. Create a new file in /etc/ssh/ssh_config.d, call it anything.conf, and as previously suggested add this one line: PubkeyAcceptedAlgorithms +ssh-rsa
It's also possible to test this directly in your SSH command before creating the file by adding -o PubkeyAcceptedKeyTypes=+ssh-rsa as an additional option. Worked for me.
pothi
Sun Dec 04, 2022 6:13 am
Same issue. Thanks @nagylzs for creating this topic and thanks to @eworm for sharing the solution. @mt99 That's a nice tip too!
Here's the one-liner that I did to automate it in Ubuntu 22.04 and in future Ubuntu versions...
echo "PubkeyAcceptedAlgorithms +ssh-rsa" | sudo tee /etc/ssh/ssh_config.d/rsa-support.conf
No need to restart SSH, as it is a client side configuration.
aseques
Fri Jan 13, 2023 1:23 pm
As @eworm mentioned on another thread, from router OS 7.7 the ed25519 keys are supported, from the changelog:
*) ssh - added support for Ed25519 key exchange;
*) ssh - do not allow SHA1 usage with strong crypto enabled;
*) ssh - fixed handling of non standard size RSA keys;
So you could create a new key with this:
ssh-keygen -t ed25519 -b 4096
mkx
Fri Jan 13, 2023 2:47 pm
Wrong:
as highlited: Ed25519 is currently only supported for key exchange. Which doesn't mean that Ed25519 public/private keys are supported (they still are not).
eworm
Fri Jan 13, 2023 7:14 pm
That is not true. I did not write that.
To date only ed25519 key exchange is supported. Let's hope we will see support for host keys and public key authentication soon.
aseques
Wed Feb 01, 2023 11:49 am
You're right, I missunderstood your comments, let's see if they add the ed25519 for authentication soon...
Users browsing this forum: d2t, Semrush [Bot] and 22 guests
