kbch
IPv6 Address Pool decision
Mon May 02, 2022 9:03 pm
I receive a /48 IPv6 Prefix from my Provider. This prefix is split into /64 for LAN assignment. This works, but I can't choose the prefix the Mikrotik will generate.
Example:
 #    ADDRESS                      FROM-POOL  INTERFACE  ADVERTISE
 0  G XXXX:XXXX:d80b::1/64          init7      vlan50     yes
 1  G XXXX:XXXX:d80b:1::1/64        init7      vlan90     yes
I don't know how to define which one of the Interface will get the prefix with 1. It would be nice if I could put 50 and 90 corresponding to the VLAN Tags into the prefix. This was very easy to do on Ubiquiti EdgeMax.
Address Config:
/ipv6 address
add address=::1 from-pool=provider interface=vlan50
add address=::1 from-pool=provider interface=vlan90
tdw
Re: IPv6 Address Pool decision
Mon May 02, 2022 11:07 pm
You can't, as discussed in several forum topics. It would be nice if you could do
/ipv6 address
add address=::50:0:0:0:1 from-pool=provider interface=vlan50
mkx
Tue May 03, 2022 8:28 am
With /48 prefix it might even be possible (it isn't if prefix is longer than 48=64-16 because ROS doesn't allow setting bits in suffix which might overlap with prefix bits ... even if they don't). There's a gotcha: one has to use the double colon "::" to mark the prefix and then use enough of ":0" to fill in the suffix ... exactly as in example by @tdw.
tdw
Tue May 03, 2022 12:35 pm
Last time I tried, probably on 6.48.6, with a /48 it didn't appear to work, may be different in v7.
kbch
Tue May 03, 2022 5:36 pm
Filling the prefix seems to also not work on v7:
;;; address pool error: bad preferred prefix! (1)
 1 IG ::90:0:0:0:1/64              provider      vlan90     yes
Users browsing this forum: No registered users and 86 guests
