Tomas530
LTE12 Chateau + iskra p58
Mon May 02, 2022 10:14 pm
Hello how properly connect u mimo iskra 58 antennas? Now i connect existing sma 2x connections in router and set external antenas to BOTH but signal is the same as no antenna connected.
hecatae
Re: LTE12 Chateau + iskra p58
Thu May 05, 2022 11:38 pm
Which mobile network are you using, you may need to add additional sma pigtails.
Photos of the internals can be found here:
https://mikrotikon.pl/mikrotik-chateau- ... uteros-v7/
Tomas530
Tue May 10, 2022 8:48 am
Solved open front panel disconnect stock antenas put existing sma to mimo1 2 and connection on rear panel antennas. Settings external antennas to none but later check another options now speed 81mpbs and 12 mb upload
hecatae
Tue May 10, 2022 1:18 pm
Glad to hear you have fixed it.
Users browsing this forum: Amazon [Bot], dioeyandika, jh1 and 71 guests
