DanieleR
Special User Permission
Tue May 03, 2022 10:12 am
Hi Guys
I'm new mikrotik user, i work with it by 1 year.
I have a particular goal, i try to read more topic but i didn't find anything.
I would like create a user that can't modify router configuration BUT can modify only DHCP lease ( permit user to make static one IP)
It possibile do?
With Radius or tips mikrotik?
rextended
Re: Special User Permission  [SOLVED]
Tue May 03, 2022 10:54 am
Mi dispiace, but permissions cannot be assigned in such a granular way.
Sob
Tue May 03, 2022 5:05 pm
Can't it be done with "skins" feature? I don't know, I just have rough idea what it does and noticed that it was added to WinBox too.
rextended
Tue May 03, 2022 5:08 pm
Simply "hiding" on menu do not reduce user power... ;)
pe1chl
Tue May 03, 2022 5:22 pm
When you are going to use radius maybe it is possible (with an external server that issues the IP addresses) but maybe it is easier to make the external server do DHCP.
rextended
Tue May 03, 2022 5:29 pm
💡 Like using MetaROUTER (on supported devices) just for DHCP-Server... RIGHT!
bpwl
Tue May 03, 2022 5:31 pm
In the "old" days we solved this by making a script for the required action, and allowed the script to be executed, or the scheduled job with the script to be executed.
(Typical: emergency shutdown of a server, resetting a password, restart a printer ...). (Some scripts even had to check the username of the executor)
Not sure this can be done here.
rextended
Tue May 03, 2022 5:35 pm
On "automatic" way, but is not the OP case, but can be a soluction, some topic talk about one script (al-ready-ready) for automatically convert dynamic leases to static.
Users browsing this forum: complexxL9, rextended, robibert, sch and 63 guests
