lodilodilodi
traffic monitoring
Wed May 04, 2022 1:18 am
is there any simple way to monitor wan traffic on mikrotik and se daily report , for example
public ip 208.65.1.1
i want to know how many mbps was one ip i chose to monitor all day long ...
Note : i dont want for lan ip , i want to monitor e public ip my users connect to that ip.
holvoetn
Re: traffic monitoring
Wed May 04, 2022 1:31 pm
Look for user jotne, he has a complete solution to track whatever you want using Splunk.
fragtion
Wed May 04, 2022 1:38 pm
Have a look at kid control, it can probably do what you're asking for quite elegantly
Another option is to create a firewall passthrough rule in the forward chain with that public IP as the dst-address, and then you can just monitor the counters for that rule, and reset the counters daily if you want..
/ip/firewall/mangle/add chain=forward in-interface-list=LAN out-interface-list=WAN dst-address=208.65.1.1 action=passthrough comment="traffic counter for public ip 208.65.1.1"
/system/scheduler/add name="reset-traffic-counters" interval=1d start-date=may/04/2022 start-time=00:00:00 on-event="/ip/firewall/mangle/reset-counters [find where comment~\"^traffic counter for public ip*\"]"
Of course you could also be more specific and only monitor traffic between that public IP and a single host in your LAN (eg 192.168.0.123), as follows:
/ip/firewall/mangle/add chain=forward in-interface-list=LAN out-interface-list=WAN src-address=192.168.0.123 dst-address=208.65.1.1 action=passthrough comment="traffic counter for public ip 208.65.1.1"
You could also modify the scheduler script to send a daily report of the traffic via E-mail before resetting it, something as follows:
/system/scheduler/add name="reset-traffic-counters" interval=1d start-date=may/04/2022 start-time=00:00:00 on-event="\
:local bytes [/ip/firewall/mangle/get [find where comment=\"traffic counter for public ip 208.65.1.1\"] bytes]\r\n\
/tool/e-mail/send to=email@address.com subject=\"Traffic report for public IP 208.65.1.1\" from=username@domain.com server=imap.domain.com port=587 tls=no user=username@domain.com password=\"123456\" body=\"Daily traffic for 208.65.1.1: \$bytes bytes\"\r\n\
lodilodilodi
Thu May 05, 2022 1:27 am
i have done this but wont show me real time traffic i can view in torch right now it says +200mbps that ip , when i check to mangle i cant real time traffic .
How can it be done with kid control ?
k6ccc
Thu May 05, 2022 2:35 am
You can also set up a passthough firewall rule that's only purpose is to count packets. May not give exactly what you are looking for, but at least some idea how much traffic is going to of from a particular IP. I do this from time to time - mostly as a troubleshooting took. For example, am I receiving any tcp traffic from 1.2.3.4 that is destined to port 12345.
lodilodilodi
Thu May 05, 2022 6:51 pm
thats the problem i want the exact traffic i am getting from that ip , because i am paying to access that ip . they are charging me alot because i dont have graph to know exactly how much i am using :) . no problem thanks all maybe isnt possible ...
chechito
Thu May 05, 2022 7:05 pm
you can create a simple queue for that particular source-destination traffic with a very high limit to avoid limiting
then you enable graphing for that simple queue, in that way you can get a simple historical graph
if you need create some kind of log you can configure disk logging and use a simple script to save queue stats using log entryes or a firewall rule counting for that traffic
lodilodilodi
Fri May 06, 2022 9:10 am
How to do that , can you guide me ?
Jotne
Fri May 06, 2022 9:56 am
holvoetn
Fri May 06, 2022 10:04 am
Which was what I already suggested in post #2 :lol:
Users browsing this forum: Google [Bot], sebi099 and 199 guests
