Lucek
MikroTik hAP Lite as OVPN Client
Wed May 04, 2022 4:17 pm
Hello everybody in my first topic,
I have two MikroTik hAP Lite. One of them is OVPN Server, second one is AP in my home. I using computer conected by Wi-Fi to second MikroTik as OVPN Client and after establish connection I connecting via RDP to computer in first MikroTik LAN.
I would like to connect second MikroTik as OVPN Client. My configuration file which working properly on computer/phone:
client
dev tun
proto tcp
remote example_address example_port
resolv-retry infinite
nobind
persist-key
persist-tun
askpass /etc/openvpn/client/Klient5.pass
ca /etc/openvpn/client/ca.crt
cert /etc/openvpn/client/klient5.crt
key /etc/openvpn/client/klient5.key
remote-cert-tls server
cipher AES-256-CBC
auth SHA1
auth-user-pass /etc/openvpn/client/auth.txt
#redirect-gateway def1
route 192.168.88.0 255.255.255.0
verb 3
I configure interface:
profile:
certificats:
And I getting filed:
Thanks for any suggestions what I doing wrong :)
tdw
Re: MikroTik hAP Lite as OVPN Client  [SOLVED]
Wed May 04, 2022 5:42 pm
Likely you have selected the wrong certificate for the OVPN client - it should be the client certificate, not the CA or server certificate.
The CA and any intermediate certs used by the server only have to be installed under System > Certificates so the can be found when Verify Server Certificate is enabled.
Lucek
Thu May 05, 2022 10:50 am
I change it to client certificate, and now it is working! Thank you!
Users browsing this forum: No registered users and 22 guests
