arnaldo
PKCS#12 certificate import not working on 7.2.2
Wed May 04, 2022 9:11 pm
I'm trying to import a PKCS#12 certificate and key under 7.2.2 and it's not finding anything inside the P12 file.
/certificate/import  file-name=test.p12 passphrase=fd6eef05
     certificates-imported: 0
     private-keys-imported: 0
            files-imported: 0
       decryption-failures: 0
  keys-with-no-certificate: 0
I've double checked the file (downloaded from the RB5009 to my desktop) with openssl and all the certificate and key were all there.
I use it (with a script) to upload my LetsEncrypt certificate periodically. Worked like a charm for months, including some 7.x versions (I don't recall last time it worked, so I'm not sure of the exact version).
Any ideas?
eworm
Re: PKCS#12 certificate import not working on 7.2.2
Thu May 05, 2022 12:11 am
Usually this indicates the certificate is in the store already...
Last time I tested it worked for me, but that was some weeks ago already - I can not name the exact version.
arnaldo
Thu May 05, 2022 3:11 pm
Thanks for the pointer!
I've checked that already. But reminding of it gives me a hint. I will remove all certificates (if I can export the CA key, used to sign several OpenVPN certificates) and give it a try.
The RB5009 is a fantastic workhorse, but I've already had two unfortunate upgrade episodes (one I've lost all the configuration and on the second I had to NetInstall). Maybe something related.
Users browsing this forum: Google [Bot], kosmipt, stef70 and 112 guests
