wanumet
Managed Switches and Routers blocked from Internet
Thu May 05, 2022 2:05 am
Hi
Am new here and i need help
I have switches and routers that are managed through internet but the problem is that they are being blocked by the Mikrotik CRS yet other devices are getting internet
The mikrotik is the Internet router and the public IP is configured on it.
There are no VLANS configured and neither are there Firewall or NAT rules
download/file.php?id=53178
anav
Re: Managed Switches and Routers blocked from Internet
Thu May 05, 2022 2:13 am
Can you post the config please.
/export hide-sensitive file=anynameyouwish, just ensure the public IP doesnt show anywhere.
k6ccc
Thu May 05, 2022 2:19 am
Unless you have specifically blocked something, you should not have a problem with your cloud managed devices. The devices (I assume on your LAN) establish outbound connection to to the cloud provider, and default configurations normally allow that just fine. As Anav said, post your config.
What brand of managed devices are you using? I am using Meraki WiFi, and used to use Open-Mesh, and both had no problem getting to the management cloud.
Users browsing this forum: darkmastor and 33 guests
