AiroSam
SNMP Walk works, but Get does not
Thu May 05, 2022 7:27 pm
I am trying to use an RB100AHx4 on 6.47.1 to grab a Mimosa B11 radio's signal strength with snmp-get.
The Walk command works successfully:
/tool snmp-walk address=10.10.10.10 community=public
OID        TYPE             VALUE
1.2.840.10036.1.1.1.1.4                                                 octet-string      \B5\C6\10\t$
1.2.840.10036.1.1.1.1.9                                                 octet-string      \B5\C6\10\t"
1.2.840.10036.1.1.1.1.10                                                octet-string     \00\02\03\04\05\06
1.2.840.10036.1.1.1.2.4                                                 integer          100
1.2.840.10036.1.1.1.2.9                                                 integer          100
1.2.840.10036.1.1.1.2.10                                                integer          100
1.2.840.10036.1.1.1.3.4                                                 integer          1
1.2.840.10036.1.1.1.3.9                                                 integer          1
But the Get command does not:
/tool snmp-get address=10.10.10.10 oid=1.3.6.1.4.1.43356.2.1.2.6.6.0 community=public
error - contact MikroTik support and send a supout file (3)
AiroSam
Re: SNMP Walk works, but Get does not
Thu May 05, 2022 9:09 pm
I found a workaround using snmp-walk:
:do {
:execute script={/tool snmp-walk 10.10.10.10 oid=1.3.6.1.4.1.43356.2.1.2.6.6 community=public} file=oid_data.txt
/delay 5
:local output [/file get oid_data.txt contents]
:local signal [/put [:pick $output 129 133]]
/code]
chechito
Thu May 05, 2022 9:10 pm
nice, thank you for sharing
Jotne
Fri May 06, 2022 8:26 am
Can you post the output of with oid of the line giving correct result?
Users browsing this forum: eworm, Google [Bot], kokoboko, lawe and 112 guests
