cherdonp
Enable FTP using API
Fri May 06, 2022 1:29 am
Good Day, im pretty new at Perl so forgive me if this is suppose to be simple. Hoping someone here is able to shed some light on how I can enable FTP service in the mikrotik using my perl script. Every syntax Ive tried not working but I know API is logging into the mikrotik fine from my script.
my %attrs = ("/ip/service/enable" , "=ftp");
($retval,@results) = Mtik::mtik_cmd(\%attrs);
Or
($retval,@results) = Mtik::mtik_cmd('/ip/service/enable ftp' , \%attrs);
mrz
Re: Enable FTP using API
Fri May 06, 2022 9:34 am
You need to get the ID of an entry first. And only then use that ID to enable.
cherdonp
Fri May 06, 2022 5:00 pm
Thank you for the speedy reply @mrz. So if Im following you correctly, for example I have a database pulling data for all of the Mtiks, each router has their respective ID number, service number, IP address etc. Are you referring to the ID number from my database attached to that router? Or you are referring to the ID number inside the Mtik ip/service table illustrated below?
# NAME PORT ADDRESS CERTIFICATE
0 XI telnet 23
1 XI ftp 21
2 XI www 80
3 ssh 22
4 XI www-ssl 443 none
5 api 8728
6 winbox 8291
7 api-ssl 8729
rextended
Fri May 06, 2022 5:05 pm
this ID:
terminal code
[admin@MikroTik] > :put  ([/ip service get ftp]->".id")
*1
cherdonp
Fri May 06, 2022 8:17 pm
Thank you @rextended. It make sense now.
Users browsing this forum: VladimirG and 13 guests
