kemmon
how to hide Mikrotik from ISP
Fri May 06, 2022 7:47 am
can someone explain how this is done, please?
rextended
Re: how to hide Mikrotik from ISP  [SOLVED]
Fri May 06, 2022 10:11 am
Yes, "drop all" at the end of the firewall input chain (prevent any service to be discovered from ISP/Internet)
and change MAC address of interface where ISP is connected.
kemmon
Fri May 06, 2022 4:30 pm
That's all "Drop all" and it's all good
kemmon
Mon May 09, 2022 1:21 am
Can you write the chain for me, please?
sultanbrunei
Wed May 11, 2022 4:00 am
so I just need to put DROP ALL in the last number in the firewall rule?
anav
Wed May 11, 2022 4:13 am
To all the people asking questions, do not modify or change firewall rules unless you know what you are doing!
Simply adding a block rule to your config, on the input chain, could easily lock yourself out of the router.
Ensure you have access as an admin in a higher up (in order) input chain rule
rextended
Wed May 11, 2022 11:22 am
Not exactly locked out... it is still possible to use winbox via MAC Winbox Server on LAN, if the user hasn't followed someone's "suggestion" to disable it...
Or simply enable safe-mode before do anything...
Spirch
Wed May 11, 2022 8:08 pm
and I will add, also use safe button, just in case
rextended
Wed May 11, 2022 11:30 pm
and use safe mode, if is not already writed on previous two posts...
anav
Wed May 11, 2022 11:58 pm
It looks like a button ;-P
kevinds
Long time Member
Long time Member
Mon May 16, 2022 1:13 am
What do *you* mean by hide Mikrotik from ISP?
I thought those proposed drop rules were already there by default..
Users browsing this forum: Amazon [Bot], zekino and 59 guests
