dibatech
Count split routes
Fri May 06, 2022 1:46 pm
Hi. Has anyone found a way to count split routes (ecmp routes)?
Routes that are either statically defined or imported via OSPF.
This is handy when OSPF creates split routes in more complex networks under certain conditions.
So, in essense, alert on split route.
Anybody?
mrz
Re: Count split routes
Fri May 06, 2022 2:14 pm
loop through routes and count +1 if gateway value is an array with more than one element
dibatech
Fri May 06, 2022 2:20 pm
Thank you.
dibatech
Fri May 06, 2022 3:49 pm
Final result.
:local dst
:local splitcount 0
:foreach dst in=[/ip route find] do={
    :set dst [/ip route get value-name=gateway number=$dst]
    :local elementcount 0
    :foreach i in=$dst do={
        set elementcount ($elementcount + 1)
    :if ( $elementcount > 1) do={
        #:put "$dst";
        set splitcount ($splitcount + 1)
:put "splitcount $splitcount"
rextended
Fri May 06, 2022 3:57 pm
Some conflicts here...
:local dst
used same name from local variable and variable obtained from foreach cycle
Probably the script must be like:
    :local splitcount 0
    :foreach item in=[find] do={
        :local gat [get $item gateway]
        :if ([:len $gat] > 1) do={
            :set splitcount ($splitcount + 1)
Users browsing this forum: No registered users and 53 guests
