yeremia1234
Get Real Address when Login to Mikrotik Winbox
Sat May 07, 2022 7:44 am
I have two router which connected with vpn. The router configuration like this
Router CORE
PUBLIC IP : 66.96.234.199/32
IP VPN : 172.1.23.1
Router Client
IP VPN : 172.1.23.33
I've port forward from router client to router core which that router have ip public. When i'm access Router Client with ip public + port that i've forward before, in /system active user show ip router core vpn. How can i get real address when access router client?. Sorry for my english
This is from my router client
Flags: R - radius, M - by-romon
# WHEN NAME ADDRESS
0 may/07/2022 04:13:22 admin F8:E4:3B:82:2D:57
1 may/07/2022 04:42:07 admin 172.1.23.1
2 may/07/2022 04:43:17 admin 172.1.23.1
mkx
Re: Get Real Address when Login to Mikrotik Winbox
Sat May 07, 2022 3:53 pm
You have to adjust SRC NAT rules. It's hard to tell in what way because you didn't post almost any details about configuration (both core router and client router configurations matter).
yeremia1234
Sat May 07, 2022 3:57 pm
What kind of configuration i must write it?
anav
Sat May 07, 2022 5:35 pm
Read what mkx wrote.......need more detail, please post your config as a minimum
a network diagram sometimes helps as well.
yeremia1234
Sat May 07, 2022 6:36 pm
https://drive.google.com/file/d/1diPv4J ... p=drivesdk
This is my diagram network. Maybe can help you
tangent
Sat May 07, 2022 7:05 pm
IP VPN : 172.1.23.1
Is that supposed to be a private LAN address? If so, it betrays a common misunderstanding of RFC 1918, which is that all 172.* addresses are available. That isn't the case. 172.0.0.0/12 belongs to AT&T. As long as you use their IP block on your private network, any time a DNS lookup resolves to one of their IPs, it'll get eaten by your local network configuration.
If I'm right about this, you should renumber to something in the 172.16.x.y - 172.31.x.y space.
Yes: you will indeed see an internal IP in that case. That's the wrong level to expect to see a public IP address.
Use a public IP address lookup service such as this one.
yeremia1234
Sat May 07, 2022 7:12 pm
IP VPN : 172.1.23.1
172.1.23.0/24 is local vpn ip from router core to router client. When router client connect to router core, router client get ip 172.1.23.33 from vpn tunnel. Mkv tell to use src nat its right. But i dont know how to config src nat in both of router
Users browsing this forum: Bing [Bot], garibaldo, Google [Bot], mquan1984 and 123 guests
