rsalmar
Slow speeds on rb5009 7.2.2
Sat May 07, 2022 3:47 pm
Hello! I have a rb5009 with 7.2.2 running, attached to an ISP router. If I connect to the ISP (Ethernet) I am getting 600Mbs, but if I connect to the rb5009 i get 50-60Mbs up/down (Ethernet). I have a very simple configuration (Happy to share) but I’m wondering if anyone is aware of anything obvious that could be causing this.
anav
Re: Slow speeds on rb5009 7.2.2  [SOLVED]
Sat May 07, 2022 5:46 pm
Nope, other than a bad cable ........... or the wrong cable.
/export file=anynameyouwish
rsalmar
Sat May 07, 2022 7:36 pm
I thought perhaps but I tried different cables, and all the ports are having the same problem. I just tried a bandwidth test directly on the router, and it is working at 600 Mbps. I looked over the config again and I can't see what would limit the ports.
anav
Sat May 07, 2022 7:57 pm
Either can I without seeing the config LOL
rsalmar
Sat May 07, 2022 8:01 pm
:D Apologies, I didn't want to bother anyone with the config, but you're absolutely right, can't help otherwise!
First time doing that, so let's see...
Redacted
rsalmar
Sat May 07, 2022 8:25 pm
OK more information... the interfaces are showing that they auto-negotiated to 100Mbps and not 1000Mbps. In "Advertising" it shows it is allowing all speeds from 10-1000, but in the "Link Partner Advertising" it is missing the 1000Mbps. I would suspect something in the cable line, except this is also happening with a laptop directly connected. I'll check a few more cables...
rsalmar
Sat May 07, 2022 9:13 pm
Thank you for that pointer to the cables. Total storm. Testing cable was "bad", switched it, all worked. Hmm, why didn't the others work? PoE injector is 100Mb (I bought 1Gb, time to complain).
I love this forum, always makes me think. :D
Users browsing this forum: complexxL9, critter, GoogleOther [Bot] and 128 guests
