anassar26
help me please .. how to limit users according to amount of download
Sun May 08, 2022 12:51 am
how can i limit users according to amount of download by using simple queue script ?
i have 4 users some of them download a lot and I want to limit them after they reach 4 gigabyte per day
I did simple queue for each one of them to limit upload and download rate speed
I want limit users according to amount of download
I use dhcp server in my network
I try script below and nothing happened
can anyone help me and explain steps
/queue simple {
    :for i from=1 to= 254 do={
        :local queue [find target=("10.10.10." . $i . "/32")]
        :if ([:len $queue] != 0) do={
            :local traf [get $queue total-bytes]
            :put ("Queue (" . [get $queue target] . ") traf: " . $traf)
            :if ($traf > 10) do={
            set [find target-addresses=("10.0.0." . $i)] max-limit= 32000/256000
holvoetn
Re: help me please .. how to limit users according to amount of download
Sun May 08, 2022 9:29 am
Have you disabled FastTrack?
Otherwise queues will not work.
kevinds
Long time Member
Long time Member
Sun May 15, 2022 9:31 pm
Not directly related to your issue but something I noticed..
What is the IP of your router? Is it in the 10.10.10.0/24 network? Or Is your network a /23 or larger? You likely don't want your router's IP in the script's range.
Second thing I see is that if users have admin privileges it is usually easy to change the MAC address, it is built into Android and iOS these days that they can disconnect and re-connect, depending on the settings of the saved SSID it will use a new random MAC.
chechito
Mon May 16, 2022 12:42 am
maybe this can be useful to you
viewtopic.php?t=185910
Users browsing this forum: No registered users and 37 guests
