Jefgoi
Can’t ping or fetch url from mikrotik
Sun May 08, 2022 9:05 pm
Dear, I have my Mikrotik configured to work via PCC with 2 providers. Internet is OK, also ping 1.1.1.1 and cnn.com works well. I can see the traffic goes via both wan interfaces.
But ping and /tool fetch url don’t work from mikrotik itself.
- Ping 1.1.1.1 says “no route to host”,
- Ping cnn.com says:
invalid value for argument address:
invalid value of mac-address, mac address required
invalid value for argument ipv6-address
while resolving ip-address: could not get answer from dns server
- /tool fetch url="http://1.1.1.1" says:
status: failed
failure: closing connection: <connect failed: Network is unreachable> 1.1.1.1:80 (4)
What did I configure improperly? Please help!
Config attached.
/export hide-sensitive terse
# jan/27/2022 12:19:46 by RouterOS 6.49.2
# software id = GPDH-SMCN
# model = RBD52G-5HacD2HnD
# serial number =
/interface bridge add admin-mac=48:8F:5A:BD:23:68 auto-mac=no comment=defconf name=bridge
/interface ethernet set [ find default-name=ether1 ] name=ISP1-Megafon
/interface ethernet set [ find default-name=ether2 ] name=ISP2-Beeline
/interface ethernet set [ find default-name=ether5 ] name=LAN-Home
/interface l2tp-client add connect-to=107.172.217.150 keepalive-timeout=disabled name=l2tp-out1 use-ipsec=yes user=vpnuser
/interface wireless set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX disabled=no distance=indoors frequency=auto installation=in
door mode=ap-bridge ssid=md10 wireless-protocol=802.11
/interface wireless set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto installat
ion=indoor mode=ap-bridge ssid=md10-5 wireless-protocol=802.11
/interface bonding add disabled=yes mode=balance-alb name=bonding1 slaves=ISP1-Megafon,ISP2-Beeline
/interface list add comment=defconf name=WAN
/interface list add comment=defconf name=LAN
/interface wireless security-profiles set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
/ip pool add name=dhcp ranges=192.168.88.10-192.168.88.254
/ip dhcp-server add address-pool=dhcp disabled=no interface=bridge name=defconf
/port set 0 baud-rate=9600 data-bits=8 flow-control=none name=usb1 parity=none stop-bits=1
/interface ppp-client add apn=internet dial-on-demand=no disabled=no info-channel=1 name=ppp-out1 phone=*99# port=usb1 user=beeline
/interface bridge port add bridge=bridge comment=defconf interface=ether3
/interface bridge port add bridge=bridge comment=defconf interface=ether4
/interface bridge port add bridge=bridge comment=defconf interface=LAN-Home
/interface bridge port add bridge=bridge comment=defconf interface=wlan1
/interface bridge port add bridge=bridge comment=defconf interface=wlan2
/ip neighbor discovery-settings set discover-interface-list=LAN
/interface list member add comment=defconf interface=bridge list=LAN
/interface list member add comment=defconf interface=ISP1-Megafon list=WAN
/interface list member add interface=ISP2-Beeline list=WAN
/ip address add address=192.168.88.1/24 comment=defconf interface=LAN-Home network=192.168.88.0
/ip address add address=10.0.0.1/24 interface=bonding1 network=10.0.0.0
/ip dhcp-client add add-default-route=no comment=defconf disabled=no interface=ISP1-Megafon
/ip dhcp-client add add-default-route=no disabled=no interface=ISP2-Beeline
/ip dhcp-server network add address=192.168.88.0/24 comment=defconf gateway=192.168.88.1
/ip dns set allow-remote-requests=yes
/ip dns static add address=192.168.88.1 comment=defconf name=router.lan
/ip dns static add address=159.148.172.226 disabled=yes name=upgrade.mikrotik.com
/ip firewall filter add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
/ip firewall filter add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid
/ip firewall filter add action=accept chain=input comment="defconf: accept ICMP" protocol=icmp
/ip firewall filter add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
/ip firewall filter add action=drop chain=input comment="defconf: drop all not coming from LAN" in-interface-list=!LAN
/ip firewall filter add action=accept chain=forward comment="defconf: accept in ipsec policy" ipsec-policy=in,ipsec
/ip firewall filter add action=accept chain=forward comment="defconf: accept out ipsec policy" ipsec-policy=out,ipsec
/ip firewall filter add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related
/ip firewall filter add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=established,related,untrack
ed
/ip firewall filter add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid
/ip firewall filter add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-
interface-list=WAN
/ip firewall mangle add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=ISP1-Megafon new-connection-mark=ISP1_conn
/ip firewall mangle add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=ISP2-Beeline new-connection-mark=ISP2_conn
/ip firewall mangle add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface=bridge new-connection-mark=I
SP1_conn passthrough=yes per-connection-classifier=both-addresses:2/0
SP2_conn passthrough=yes per-connection-classifier=both-addresses:2/1
/ip firewall mangle add action=accept chain=prerouting dst-address=192.168.100.0/24 in-interface=bridge
/ip firewall mangle add action=accept chain=prerouting dst-address=192.168.9.0/24 in-interface=bridge
/ip firewall mangle add action=mark-routing chain=prerouting connection-mark=ISP1_conn in-interface=bridge new-routing-mark=to_ISP1 passthrough=yes
/ip firewall mangle add action=mark-routing chain=prerouting connection-mark=ISP2_conn in-interface=bridge new-routing-mark=to_ISP2 passthrough=yes
/ip firewall mangle add action=mark-routing chain=output connection-mark=ISP1_conn new-routing-mark=to_ISP1
/ip firewall mangle add action=mark-routing chain=output connection-mark=ISP2_conn new-routing-mark=to_ISP2
/ip firewall nat add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes ipsec-policy=out,none out-interface-list=WAN
/ip firewall nat add action=masquerade chain=srcnat out-interface=ISP1-Megafon
/ip firewall nat add action=masquerade chain=srcnat out-interface=ISP2-Beeline
/ip firewall nat add action=masquerade chain=srcnat disabled=yes out-interface=ppp-out1
/ip route add check-gateway=ping distance=1 gateway=192.168.100.1 routing-mark=to_ISP1
/ip route add check-gateway=ping distance=1 gateway=192.168.9.1 routing-mark=to_ISP2
/ip route add comment=ISP1 disabled=yes distance=1 gateway=192.168.100.1
/ip route add comment=ISP2 disabled=yes distance=1 gateway=192.168.9.1
/system clock set time-zone-name=Europe/Moscow
/system scheduler add disabled=yes interval=3s name=schedule1 on-event="/system script run script1" policy=ftp,reboot,read,write,policy,test,password,sni
ff,sensitive,romon start-date=jan/26/2022 start-time=17:28:30
/system script add dont-require-permissions=no name=script1 owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":
global rx1 \"0\"\
    \n:global rx2 \"0\"\
    \n\
    \n/interface monitor-traffic ISP1-Megafon once do={:global rx1 \$(\"rx-bits-per-second\");}\
    \n/interface monitor-traffic ISP2-Beeline once do={:global rx2 \$(\"rx-bits-per-second\");}\
    \n\
    \nif (\$rx1>\$rx2) do={/ip route enable [find comment=ISP2]} else={/ip route enable [find comment=ISP1]}\
    \nif (\$rx1>\$rx2) do={/ip route disable [find comment=ISP1]} else={/ip route disable [find comment=ISP2]}\
    \n"
/tool mac-server set allowed-interface-list=LAN
/tool mac-server mac-winbox set allowed-interface-list=LAN
Sob
Re: Can’t ping or fetch url from mikrotik
Mon May 09, 2022 3:50 am
Router uses main routing table for own connections, and it currently doesn't have any route to internet. Enable at least one of those two you have disabled and it will be better.
Users browsing this forum: No registered users and 101 guests
