sultanbrunei
Unable to access mikrotik via IP address
Mon May 09, 2022 9:23 am
Hi, my mikrotik Hex router is configured using standard firewall rules.
I have to disable the "drop input for all other traffic" rule to be able to access the router from IP address.
Should I disable the rule and still feel safe, or should I make additional rule to make an exception so that my PC can access my mikrotik through IP address? How?
Thank you
erlinden
Re: Unable to access mikrotik via IP address
Mon May 09, 2022 9:56 am
I think you want to access it only from "LAN" (that's like a double hint)?
Referring to default rules, these are (assuming you do use Interface List):
add action=accept chain=input comment="accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=input comment="drop invalid" connection-state=invalid
add action=accept chain=input comment="accept ICMP" protocol=icmp
add action=drop chain=input comment="drop all not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="accept established,related, untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="drop invalid" connection-state=invalid
add action=accept chain=forward comment="accept in ipsec policy" ipsec-policy=in,ipsec
add action=accept chain=forward comment="accept out ipsec policy" ipsec-policy=out,ipsec
add action=drop chain=forward comment="drop all from WAN not DSTNATed" connection-nat-state=!dstnat in-interface-list=WAN
You might want to activate logging (or read the logging) to get some information about packets getting dropped.
sultanbrunei
Mon May 09, 2022 11:08 am
Should I ADD all of these, as firewall rules number 8-16 ?
bpwl
Mon May 09, 2022 11:45 am
Doesn't look like the standard firewall rules. The other posts show what I also get as default firewall rules. eg: add action=drop chain=input comment="drop all not coming from LAN" in-interface-list=!LAN , allowing input from LAN. "bridge1" should then be in the LAN interface list (under "interfaces" menu)
Or just make a specific rule above the "drop input for all other", allowing port 8291 from a specific interface or IP address.
own3r1138
Long time Member
Long time Member
Mon May 09, 2022 11:48 am
If you don't have any config other than what comes with MT out of the box I recommend resetting the configuration to default as the easiest way to get default firewall rules in place.
When you play with the firewall you should use "SAFE MODE".
https://help.mikrotik.com/docs/display/ ... t+Firewall
Firstly, check the above article.
You should remove all your current firewall rules and then replace them with the default firewall rules.
If you copy the rules be aware if you do NOT use fast-track you should remove "untracked" at the "connection-state".
anav
Mon May 09, 2022 4:47 pm
To be clear, first, the source of your information is in question!
Second, your knowledge of firewall rules etc is in question!
Suggest some reading first and as for guidance this is a good safe spot. - viewtopic.php?t=180838
WHEN and only WHEN you understand the difference between input chain and forward chain, destination nat and source nat,
and IP routes ( how to manually or automatically apply) and understand what each rule is doing, I highly suggest you stay away from youtube,
or anyone here with any wild ideas or seemingly complex ideas.
Users browsing this forum: No registered users and 107 guests
