kendedz
User Manager option disappear after upgrading OS
Mon May 09, 2022 10:11 am
Hello, my usermanager option missing at mikrotik terminal after I upgrade my router.
I'm using RB1100AHx2 and my current firmware is 7.2.3
own3r1138
Long time Member
Long time Member
Re: User Manager option disappear after upgrading OS  [SOLVED]
Mon May 09, 2022 10:26 am
The new CLI is
user-manager
kendedz
Mon May 09, 2022 10:46 am
The new CLI is
user-manager
Thank You Sir, for your reply
But after I check with terminal, my user manager is disabled
rextended
Mon May 09, 2022 11:00 am
@kendedz
you do not have user-manager like before...
v6 and v7 use-manager are like completely different...
kendedz
Mon May 09, 2022 11:39 am
@kendedz
Ok sir, thank you for your information
I already downgrade my OS to OS 6
It's not just usermanager error, but my hotspot page wont appear too
I'll learn about OS 7 first and then I'll try again later
Thank You again sir :D :D
Users browsing this forum: No registered users and 30 guests
