aoakeley
Routing Table Column in IP-Routes in Winbox default view
Mon May 09, 2022 12:45 pm
Does anyone else think the "Routing Table" column in IP-Routes in winbox should be shown by default in v7, in the same way that the "Routing Mark" column was shown by default in v6?
It is not the end of the world to enable it each time, but I would find it nice if it was enabled by default as it was in v6.
Wondering if anyone else felt the same way?
rextended
Re: Routing Table Column in IP-Routes in Winbox default view
Mon May 09, 2022 2:35 pm
You can do yourself saving the session as default session on winbox.
Sob
Mon May 09, 2022 4:21 pm
Yes, but it should be also visible by default, because it's important piece of info, almost as destination address or gateway. It was in v6 and there's no good reason to remove it. Btw, with IPv6 in v7 it's even worse, it doesn't even show gateway by default.
aoakeley
Fri May 13, 2022 2:41 am
When you connect to thousands of different routers, often using different IP's, this is not practical.
aoakeley
Fri May 13, 2022 2:43 am
Glad I am not the only one that thinks this.
Users browsing this forum: No registered users and 24 guests
