riflooping
RouterOS over 6.48.6 & Rancid
Mon May 09, 2022 12:57 pm
Hi erveryone !
I am currently encountering a problem.
When I want to download a file on a mikrotik in 6.48.6 using mtlogin and fetch tool, it works perfectly and the script waits until the router has finished downloading to send a "quit".
However, when trying the same manipulation on a router with version over 6.48.6, the "quit" is sent directly, thus stopping the download because of the letter Q and thus sending "uit" thereafter in the prompt.
The prompts are similar for 6.48.6 and over, and even when trying to add expects in the script, the result is the same. I think the problem is in this part of the code, but don't know how to fix it.
# Run commands given on the command line.
proc run_commands { prompt command } {
    global do_interact in_proc
    set in_proc 1
    # escape any parens in the prompt, such as "(enable)"
    regsub -all "\[)(]" $prompt {\\&} reprompt
    # handle escaped ;s in commands, and ;; and ^;
    regsub -all {([^\\]);} $command "\\1\u0002;" esccommand
    regsub -all {([^\\]);;} $esccommand "\\1;\u0002;" command
    regsub {^;} $command "\u0002;" esccommand
    regsub -all {[\\];} $esccommand ";" command
    regsub -all {\u0002;} $command "\u0002" esccommand
    set sep "\u0002"
    set commands [split $esccommand $sep]
    set num_commands [llength $commands]
    for {set i 0} {$i < $num_commands} { incr i} {
    send -- "[subst -nocommands [lindex $commands $i]]\r"
    if { [lindex $commands $i] == "/system/reboot"} {
        send "y\r"
    expect {
        -re "^\[^\n\r]*$reprompt"       {}
        -re "^\[^\n\r ]*>>.*$reprompt"  { exp_continue }
        -re "\[\n\r]+"          { exp_continue }
    if { $do_interact == 1 } {
    interact
    return 0
    send "quit\r"
    expect {
    -re "^WARNING: There are unsaved configuration changes." {
                         send "y\r"
                         exp_continue
    "\n"                    { exp_continue }
    "\[^\n\r *]*Session terminated"     { return 0 }
    timeout                 { catch {close}; catch {wait};
                          return 0
    eof                 { return 0 }
    set in_proc 0
That's how it looks like:
Does anyone have a solution?
riflooping
Re: RouterOS over 6.48.6 & Rancid
Mon May 16, 2022 4:12 pm
Hi everyone,
I just found the solution, in mtlogin script at line 625 :
foreach router [lrange $argv $i end] {
    set router [string tolower $router]
    send_user "$router\n"
    # Figure out prompt.
    set prompt "] >  "  #Just added a second whitespace after >
    # alteon only "enables" based on the password used at login time
    set autoenable 1
    set enable 0
Hope it's gonna help you !
Users browsing this forum: Bing [Bot], djvabe, Google [Bot] and 115 guests
