Santi70
outgoing traffic
Mon May 09, 2022 3:36 pm
Hello, every night I am seeing an outgoing traffic in the early hours of the morning when everyone is asleep, how can I know which is the equipment that makes that connection, differentiating it by the amount of traffic compared to the others?
thank you
mkx
Re: outgoing traffic
Mon May 09, 2022 6:17 pm
Try to correlate the spike you see with traffic on other router interfaces (other than WAN). But generally it's hard to catch it without using some sort of sniffing around.
Santi70
Mon May 09, 2022 7:02 pm
The problem is that all the equipment is connected via WIFI, so I only have one interface in use NO WAN
mkx
Mon May 09, 2022 9:05 pm
In that case ... good luck finding the "offender"
rextended
Mon May 09, 2022 9:15 pm
Try to turn off smartphone, and they do not do backup on cloud...
anav
Mon May 09, 2022 9:29 pm
Use time of day scheduling, no internet between 0200AM and 0600AM
Users browsing this forum: DanMos79, frankyees, jmszuch1, Majestic-12 [Bot], Qanon, tnperron, UkRainUa and 162 guests
