MrMista
5Ghz WiFi SSID not appearing after factory reset
Tue May 10, 2022 7:18 pm
I was having some WiFi issues so I decided to reset my Mikrotik to factory settings, but still use the same SSID's and passwords. The 2.4Ghz radio immediately began working but I am unable to see 5Ghz. I am based in the USA and have "unitedstates3" selected as my profile. Since this is the factory reset settings, I'd think they should work, does anyone notice any issues in this config? Thank you!
I had posted this to Reddit and someone said to "Disable DFS" but I do not see this in the settings. I do see a way to change the "Frequency" of 5GHz from "auto" to "5180" (these are the only 2 options), but neither work.
 [admin@MikroTik] > export hide-sensitive
# may/08/2022 17:09:20 by RouterOS 7.2.3
# software id = CE9T-511L
# model = RB4011iGS+5HacQ2HnD
# serial number = F03D0EEEE5F2
add admin-mac=2C:C8:1B:4A:A2:A7 auto-mac=no comment=defconf name=bridge
/interface wireless
# no supported channel and secondary channel combination
set [ find default-name=wlan1 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge secondary-frequency=auto ssid=ShowerWebcam5G wireless-protocol=802.11
set [ find default-name=wlan2 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country="united states2" disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=ShowerWebcam2.4G wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
add authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys name=profile supplicant-identity=MikroTik
/interface wireless
add disabled=no mac-address=2E:C8:1B:4A:A2:B1 master-interface=wlan1 name=wlan3 security-profile=profile ssid=ShowerWebcamGuest
add disabled=no mac-address=0A:55:31:FE:AD:DE master-interface=wlan2 name=wlan4 security-profile=profile ssid=ShowerWebcamGuest
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
/port
set 0 name=serial0
set 1 name=serial1
/interface bridge filter
add action=drop chain=forward in-interface=wlan3
add action=drop chain=forward out-interface=wlan3
add action=drop chain=forward in-interface=wlan4
add action=drop chain=forward out-interface=wlan4
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=wlan3
add bridge=bridge interface=wlan4
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.88.216 mac-address=24:5E:BE:23:78:03 server=defconf
add address=192.168.88.116 client-id=1:60:45:cb:80:dc:e3 mac-address=60:45:CB:80:DC:E3 server=defconf
add address=192.168.88.48 client-id=1:8:0:2c:c9:2f:83 mac-address=08:00:2C:C9:2F:83 server=defconf
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes servers=192.168.88.48,1.1.1.1
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=America/New_York
/system leds
add interface=wlan2 leds=wlan2_signal1-led,wlan2_signal2-led,wlan2_signal3-led,wlan2_signal4-led,wlan2_signal5-led type=wireless-signal-strength
add interface=wlan2 leds=wlan2_tx-led type=interface-transmit
add interface=wlan2 leds=wlan2_rx-led type=interface-receive
/tool mac-server
/tool mac-server mac-winbox
Ca6ko
Long time Member
Long time Member
Re: 5Ghz WiFi SSID not appearing after factory reset
Wed May 11, 2022 10:22 am
Wrong in the above configuration it is not
There should be an entry "country="united states3"
Mikrotik wrote the reason for the error "# no supported channel and secondary channel combination"
An unsupported combination of centre channel and auxiliary channel frequencies has been selected.
An error seems to have occurred during automatic tuning
Set the following settings and everything will work
 channel-width=20/40mhz-XX country="united states3" frequency=5180
Strange setting "secondary-frequency=auto " I don't have this on 7.2.3. If you have it in your settings, this field should be left blank. This setting was present in the old versions, it is not used in the new ones.
MrMista
Wed May 11, 2022 5:47 pm
I did see that Mikrotik was telling me what the issue was, but not how to fix it given what I see in the WebUI
Interesting, you are right that the config I posted does not show "unitedstates3". There must be some bug with the UI:
Is there a command I can run in the terminal to set the setting you provide? I think because of this UI bug I am unable to fix my issue.
MrMista
Wed May 11, 2022 6:15 pm
I think I managed to set the proper setting through Webfig which gave me access to disable "secondary-channel" on the 5Ghz interface:
# may/11/2022 11:15:13 by RouterOS 7.2.3
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX disabled=no distance=indoors installation=indoor mode=ap-bridge ssid=ShowerWebcam5G wireless-protocol=802.11
set [ find default-name=wlan2 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country="united states3" disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=ShowerWebcam2.4G wireless-protocol=802.11
/interface wireless
/port
set 0 name=serial0
set 1 name=serial1
/ip dhcp-client
/ip dns static
/system clock
/system leds
/tool mac-server
Users browsing this forum: No registered users and 115 guests
