lurch
allowing traffic between vlans
Wed May 11, 2022 10:53 am
Using the following configuration on a device plugged into ether12 on vlan100 i'm unable to ping a device on vlanid please could someone tell me what firewall (i assume) rule i would need or is it something else?
add admin-mac=xxxxxxxxxxx auto-mac=no comment=defconf name=bridge \
    vlan-filtering=yes
/interface vlan
add interface=bridge name=vlan100 vlan-id=100
add name=WAN
add name=LAN
add name=vlan100_pool ranges=10.20.20.1-10.20.20.253
add address-pool=vlan100_pool bootp-support=none disabled=no interface=vlan100 \
    lease-time=1d name=vlan100_dhcp
add bridge=bridge comment=defconf interface=ether12 pvid=100
/interface bridge vlan
add bridge=bridge vlan-ids=1
add bridge=bridge tagged=sfp-sfpplus1,bridge vlan-ids=100
    192.168.88.0
add address=10.10.0.9/24 interface=ether2 network=10.10.0.0
add address=10.20.20.254/24 interface=vlan100 network=10.20.20.0
add address=10.20.20.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=10.20.20.254 \
    netmask=24
add action=masquerade chain=srcnat out-interface=bridge src-address=\
    10.20.20.0/24
Sahafi2001
Re: allowing traffic between vlans
Wed May 11, 2022 11:22 am
Try to do like this
add bridge=bridge interface=ether12
add bridge=bridge tagged=ether12 vlan-ids=100
add address=10.10.0.9/24 interface=ether12 network=10.10.0.0
lurch
Wed May 11, 2022 1:30 pm
Hi thanks but i'm a bit confused does that mean I would have to do this for every port I want to allow traffic to flow between the vlans for?
ether12 is already a bridge port
[admin@RouterOS] /interface bridge port> add bridge=bridge interface=ether12
failure: device already added as bridge port
Zacharias
Wed May 11, 2022 1:40 pm
Can you show a network diagram of your topology and point on the traffic that you assume it is blocked ?
erlinden
Wed May 11, 2022 1:42 pm
Can you please have a look at this great topic about VLAN's:
viewtopic.php?f=23&t=143620
By default all intervlan communication is allowed, you have to block it manually.
lurch
Wed May 11, 2022 1:56 pm
Hi I just rebooted the router and inter vlan started working most strange thank you for your help
Users browsing this forum: gigabyte091 and 97 guests
