lurch
poor bridge/vlan throughput
Wed May 11, 2022 2:00 pm
with different devices plugged into the same switch on ports 9&11 with vid 1 doing an iperf I get 900mbits throughput however if i change port 11 to vlan100 I only get an erratic 250mbits any idea why this may be?
add admin-mac=xxxxxxxxxxx auto-mac=no comment=defconf name=bridge \
    vlan-filtering=yes
/interface vlan
add interface=bridge name=vlan100 vlan-id=100
add name=WAN
add name=LAN
add name=vlan100_pool ranges=10.20.20.1-10.20.20.253
add address-pool=vlan100_pool bootp-support=none disabled=no interface=vlan100 \
    lease-time=1d name=vlan100_dhcp
add bridge=bridge comment=defconf interface=ether12 pvid=100
/interface bridge vlan
add bridge=bridge vlan-ids=1
add bridge=bridge tagged=sfp-sfpplus1,bridge vlan-ids=100
    192.168.88.0
add address=10.10.0.9/24 interface=ether2 network=10.10.0.0
add address=10.20.20.254/24 interface=vlan100 network=10.20.20.0
add address=10.20.20.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=10.20.20.254 \
    netmask=24
add action=masquerade chain=srcnat out-interface=bridge src-address=\
    10.20.20.0/24
tdw
Re: poor bridge/vlan throughput
Wed May 11, 2022 2:11 pm
Between devices on the same VLAN you are bridging layer 2 traffic, a Mikrotik which supports hardware-offloading on a vlan-aware bridge will pass this at wire speed.
Between devices on different VLANs you are routing layer 3 traffic, this is limited by the CPU performance of the Mikrotik unless you have a model which supports layer 3 hardware-offload and have configured it appropriately.
anav
Wed May 11, 2022 2:21 pm
The config needs work.
Zacharias
Wed May 11, 2022 2:24 pm
What is the device model you are using ?
lurch
Wed May 11, 2022 3:04 pm
Thanks for that i'm using a CRS354-48G-4S+2Q+ do you know how if this supports layer 3 hardware-offload?
Happy for any input on improving it
CRS354-48G-4S+2Q+
erlinden
Wed May 11, 2022 3:13 pm
lurch
Wed May 11, 2022 3:33 pm
Thanks so what chanbges do i need to make to my config without breaking the dhcp etc?
Zacharias
Wed May 11, 2022 3:55 pm
CRS354 supports L3 hardware offload after ROS v7.1...
https://help.mikrotik.com/docs/display/ ... 2000Series
lurch
Thu May 12, 2022 12:36 pm
I've upgraded SWOS and enabled layer 3 hardward offload on all ports and chip but now performance is even worse at 140mbit/s
# may/12/2022 10:30:46 by RouterOS 7.2.3
# model = CRS354-48G-4S+2Q+
add admin-mac=xxxxxx auto-mac=no comment=defconf \
    ingress-filtering=no name=bridge vlan-filtering=yes
/interface vlan
/interface ethernet switch
set 0 l3-hw-offloading=yes
add name=WAN
add name=LAN
/interface lte apn
add address-pool=vlan100_pool bootp-support=none interface=vlan100 lease-time=\
/port
set 0 name=serial0
add bridge=bridge comment=defconf ingress-filtering=no interface=ether12 \
    pvid=100
    192.168.88.0
add address=10.20.20.254/24 interface=vlan100 network=10.21.0.0
    netmask=24
set servers=1.1.1.1
    10.20.20.0/24
Users browsing this forum: AndreKR, qatar2022, Tony93 and 126 guests
