charleselie
rb4011 With crs328 config
Wed May 11, 2022 2:09 pm
Hi all
I have a mikrotik network which is:
Internet === RB4011/ ether 1 WAN (192.168.0.1) and ether 2 LAN (192.168.2.1) / ====== CRS328 / ether 2 receives lan (192.168.2.254) and the other 6 ether are cabled to the points of access to transmit in a wifi zone.//
how to make the configuration to emit a wifi zone?
Zacharias
Re: rb4011 With crs328 config
Wed May 11, 2022 2:28 pm
If by that you mean a seperate network, then you can use VLANs.
tangent
Wed May 11, 2022 2:35 pm
RB4011
Which one? The one without built-in WiFi, or the one with it? You can see how we might be confused when you bring up WiFi but then talk about Ethernet ports.
You really should use the SFP+ ports for this, to get a 10G link between them. Even if your Internet connection is gigabit or slower, you'll benefit from aggregating the RB4011's ten GigE ports into a single 10G link back to the core switch, the role your CRS328 is best suited for.
emit a wifi zone
I don't know what that phrase even means. What is emitting in this instance, and what is a "wifi zone"?
I can guess, but I'd rather you try rephrasing it.
charleselie
Wed May 11, 2022 3:32 pm
Here is an image of the topography of the network:
charleselie
Wed May 11, 2022 3:47 pm
help me
erlinden
Wed May 11, 2022 3:50 pm
That is like a complete flat network, assuming the clients will get a 192.168.0.0/24 address.
Can you please confirm? Because if that is the case, you don't need VLAN at all.
tangent
Wed May 11, 2022 3:54 pm
Yup. Plug it all in as diagrammed, turn it on, set the IPs, done. The stock RB4011 router config should need only trivial adjustments for your IP scheme and port assignments.
What’s the difficulty?
charleselie
Wed May 11, 2022 3:57 pm
192.168.0.0/24 is for wan (ether 1)
clients will get 192.168.2.0/24 is located on (ether 2)
charleselie
Wed May 11, 2022 3:59 pm
the difficulty is that not all customers receive the internet connection.
charleselie
Wed May 11, 2022 4:13 pm
our network is down help me please
Zacharias
Wed May 11, 2022 4:16 pm
How can actually someone help you with almost no valuable information provided ?
For example an export of your configurations with sensitive information removed and a more detailed analysis of what the problem is...
charleselie
Wed May 11, 2022 4:30 pm
HERE IS THE SETUP
Users browsing this forum: No registered users and 12 guests
