Hey everyone -
Had a quick question on forwarding the webgui (port 8006) that is within a Vlan to my workstation that is out of the Vlan.
Long story short, I have two routers, one that is from the ONT to the isp router and then to the mikrotik router. The mikrotik router has a Vlan that the pro mox server is located on (10.10.10.0/24, its ip is 10.10.10.250) However, the workstation that I want to access is connected to the isp router (ip of 192.168.1.60).
I went into the firewall rules and forwarded port 8006 through ether 1 (which connects from the mikrotik to the ISP router), and then went into nat and did dst-nat to 10.10.10.250 port 8006) under action. I moved the firewall rule above drop/input too.
It doesn’t seem to connect. I keep on getting “timeout” and when I torched it looks like it’s stuck at SYN. Any ideas? I followed the steps in the firewall forum and got my web server within the Vlan to work from my 192 workstation, so I’m wondering whether the https is throwing it off when trying to forward to proxmox.
Thanks for the help.
D
