Aybars
domain forwarding on mikrotik
Thu May 12, 2022 2:35 pm
Helloes
i have web based software and i put it on a win10 pc. now i want to enter this pc ip:8081 via domain like farm.control:8081 or like this. i have a network and have few pc on it like 6-8. so i think dns service can make this from mikrotik routers. but i dont t know how ll i do this. hope it can be done with this way or any other way. Thank you for your help guys.
erlinden
Re: domain forwarding on mikrotik
Thu May 12, 2022 2:44 pm
You have to add a static DNS entry.
Is your router the (only) DNS server for the clients?
Aybars
Thu May 12, 2022 2:50 pm
You have to add a static DNS entry. "NO"
Is your router the (only) DNS server for the clients? "NO"
i dont know how to do actually :/
erlinden
Thu May 12, 2022 2:59 pm
Adding is really simple:
https://linux-sys-adm.com/how-to-make-s ... -mikrotik/
But...if clients are (also) using public DNS servers (instead of only using the MikroTik as only DNS server) you won't be able to solve it centrally.
Only other option is to add DNS entries on all clients manually (nope...you have to Google that yourself ;-) )
Aybars
Thu May 12, 2022 4:12 pm
hahahaha i wish to google it myself and do it but i m really deadly newbie on network. hope i can learn more soon if i catch some free time. Thanks bro.
anav
Thu May 12, 2022 4:16 pm
The requirements/request is not clear to me.
You have software you run on your network behind the MT router?
It needs to be accessible to users coming from the internet?
It needs to be accessible to users also behind the router?
To reach the server from external sources Yes, you can
a. assign a dyndns name to your public IP connection OR
b. use the MT cloud name
Users coming from the outside would use URL:port# to access your server.
You would need to port forward that port to the webserver.
rextended
Thu May 12, 2022 7:05 pm
Helloes
why do not use diretly http://192.168.88.11:8081 ?
if are all windows pc, simply modify hosts file (-> google) and add
farmcontrol.local 192.168.88.11
or simply again change the name of the machine with farmcontrol (-> google) and change default suffix to local (-> google) without the point
and on various pc you can open http://farmcontrol.local:8081
Users browsing this forum: GoogleOther [Bot], Javokhir, patrikg, unhuzpt, zalciukaz and 110 guests
