egn
Mikrotik 450G
Thu May 12, 2022 8:47 pm
I'm having an issue where I'm getting a notice from ISP regarding a computer on network running Honeypot HTTP scanner on port 80. Is there a way to block all users from running port scanners using port 80 on Mikrotik router?
rextended
Re: Mikrotik 450G
Thu May 12, 2022 9:03 pm
block port 80?
do you want block http?
use torch or use connection tracking to see who is do outside scan....
egn
Re: Mikrotik 450G
Fri May 13, 2022 5:42 am
I tried using torch or connection monitoring but all computers use port 80 for traffic. The incident logs show this:
threat: Honeypot HTTP Scanner
type: tcp
source port: 57612
destination port: 80
destination ip: XX.XXX.XXX.XXX
I guess if I block destination port 80 and source range 55000 to 60000 that might do it, how can I apply this rule?
rextended
Re: Mikrotik 450G
Fri May 13, 2022 10:49 am
you must "syslog" all your firewall new connection for discovery who is, based on report date, time, IP and port....
egn
Re: Mikrotik 450G
Fri May 13, 2022 7:27 pm
Where do I go to do this?
Users browsing this forum: Amazon [Bot], Semrush [Bot] and 122 guests
