papaku
PoE Switch Options?
Fri May 13, 2022 11:39 am
I'm ordering the stuff for my buddy's new house. We've decided to go with a mix of "wsAP ac lite's" and "cAP ac XL's". These will be hard-wired 1G ethernet backhaul to an RB4011.
Somewhere in this mix I'm going to need a switch the provides PoE to the access points.
I'll be honest: I've had mixed success with MT APs' ability to take PoE. I suspect it's because most switches I've dealt with (cough netgear cough) provide Active PoE and MT seems to use a lot of Passive PoE.
Can someone point me to a decent, reliable switch that will provide (at least) 8 PoE outputs that will power up the wsAPs and cAPs we've chosen?
Thanks in advance!
rextended
Re: PoE Switch Options?  [SOLVED]
Fri May 13, 2022 2:44 pm
Zacharias
Fri May 13, 2022 4:50 pm
Or a CRS328 if you need more than 8 ports.
tangent
Fri May 13, 2022 5:12 pm
Or the CRS328 because it’ll give you a 10G backhaul, giving many separate 1G lanes.
Plus, the CRS3xx line is considerably more capable.
Users browsing this forum: adwlodaro, jifop, JustinLin and 125 guests
