Gnits
RB5009 SFP+ flapping
Fri May 13, 2022 4:00 pm
I have an RB5009 that has a 10Gb fiber connection to the router in the main rack.
I recently upgrade to the RB5009 because of the 2.5 Gb port and my new comcast device.
Since then, the connection between that device and my CRS317-1G-16S+ is dropping and re-establishing many times.
I recently upgraded everything to 7.2.3 and I thought it had resolved it but it is happening again.
I have just changed the connection speed on both ends to 1gb in hopes that it will help.
Both SFP+ are from the same manufacturer.
tangent
Re: RB5009 SFP+ flapping
Fri May 13, 2022 5:09 pm
This has improved in recent firmware, including the latest 7.3beta40. What are you running?
Gnits
Fri May 13, 2022 6:17 pm
I am currently running 7.2.3.
Gnits
Sat May 14, 2022 3:40 am
7.3beta40 made it worse. I need to back rev now.
tangent
Sat May 14, 2022 4:40 am
Did you set the port speed explicitly to 2.5G, autonrgotiate off, making use of the new feature?
If so, which SFP+ module are you using?
Gnits
Mon May 16, 2022 2:29 am
This has gotten so bad that i had to run an ethernet cable between two of the switches just to keep network stability.
Need to put a ticket into them.
Users browsing this forum: infabo, voytecky and 75 guests
