rg4eger
Slow internet speed in Mikrotik 2011 behind FritzBox 7590
Sat May 14, 2022 1:26 pm
Mikrotik 2011 is connected to internet thought FritzBox 7590, internet speed is 40mbs but in FritzBox (provider dsl router) is 250mbs.
What should I check?
freemannnn
Forum Veteran
Forum Veteran
Re: Slow internet speed in Mikrotik 2011 behind FritzBox 7590
Sat May 14, 2022 1:31 pm
without knowing much from your config, fasttrack rule in ip/firewall helps on this model. enable it. i have the same router with 100/10 mbps internet speed and works fine..
kevinds
Long time Member
Long time Member
Mon May 16, 2022 1:24 am
Fastpath will help a LOT but I doubt that a RB2011 will be able to do NAT at 250 mbps..
After 125-150 mbps depending on the router's configuration, it simply didn't have enough power to do the job..
Znevna
Mon May 16, 2022 9:06 am
RB2011 does well over 800Mbps with FastTrack.
If you don't use the 100Mbps ports that is.
rg4eger
Tue May 17, 2022 11:29 am
FastTrack in Filter rules & Fast Forward in Bridge is ON
The router was already with a fast path.
I have the same router in another office and everything works fine at a speed of 1 gigabit in both directions.
Users browsing this forum: Bing [Bot], ChadRT, LdB and 121 guests
