Code: Select all
/caps-man channel
add band=5ghz-n/ac name=5Ghz reselect-interval=1h
add band=2ghz-g/n name=2.4Ghz reselect-interval=1h
/caps-man interface
add disabled=no l2mtu=1600 mac-address=DC:2C:6E:2B:76:00 master-interface=none name=cap1 radio-mac=DC:2C:6E:2B:76:00 radio-name=DC2C6E2B7600
add disabled=no l2mtu=1600 mac-address=DC:2C:6E:2B:75:B8 master-interface=none name=cap2 radio-mac=DC:2C:6E:2B:75:B8 radio-name=DC2C6E2B75B8
add disabled=no l2mtu=1600 mac-address=DC:2C:6E:2B:75:F2 master-interface=none name=cap3 radio-mac=DC:2C:6E:2B:75:F2 radio-name=DC2C6E2B75F2
add disabled=no l2mtu=1600 mac-address=DC:2C:6E:2B:75:D0 master-interface=none name=cap4 radio-mac=DC:2C:6E:2B:75:D0 radio-name=DC2C6E2B75D0
add disabled=no l2mtu=1600 mac-address=2C:C8:1B:BB:C7:21 master-interface=none name=cap5 radio-mac=2C:C8:1B:BB:C7:21 radio-name=2CC81BBBC721
add disabled=no l2mtu=1600 mac-address=DC:2C:6E:2B:75:BE master-interface=none name=cap6 radio-mac=DC:2C:6E:2B:75:BE radio-name=DC2C6E2B75BE
/caps-man datapath
add bridge=bridge client-to-client-forwarding=yes local-forwarding=yes name=DaWiFi-Datapath
add bridge=guest-bridge client-to-client-forwarding=no local-forwarding=no name=DaWiFi-Guest-Datapath
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=DaWiFi-Security
add authentication-types=wpa2-psk encryption=aes-ccm name=DaWiFi-Guest-Security
/caps-man configuration
add channel=5Ghz channel.skip-dfs-channels=no country=spain datapath=DaWiFi-Datapath mode=ap name="DaWiFi (5Ghz Only)" security=DaWiFi-Security ssid=DaWiFi
add channel=5Ghz channel.skip-dfs-channels=no country=spain datapath=DaWiFi-Datapath mode=ap name=DaWiFi-5Ghz security=DaWiFi-Security ssid=DaWiFi-5Ghz
add channel=2.4Ghz country=spain datapath=DaWiFi-Datapath mode=ap name="DaWiFi (2.4Ghz Only)" security=DaWiFi-Security ssid=DaWiFi
add channel=2.4Ghz country=spain datapath=DaWiFi-Guest-Datapath mode=ap name="DaWiFi Guest (2.4Ghz Only)" security=DaWiFi-Guest-Security ssid=DaWiFiGuest
add channel.band=2ghz-b/g/n datapath=DaWiFi-Datapath mode=ap name=Test24 security=DaWiFi-Guest-Security ssid=Test24
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes upgrade-policy=suggest-same-version
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration="DaWiFi (2.4Ghz Only)" name-format=prefix-identity name-prefix=DaWiFi slave-configurations=\
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration="DaWiFi (5Ghz Only)" name-format=prefix-identity name-prefix=DaWiFi slave-configurations=\
DaWiFi-5Ghz
