Neo553
Issues with a simple setup - Cant route between LANs
Sun May 15, 2022 9:51 pm
So am trying to set up a MikroTik Cloud Router Switch CRS326-24G-2S+RM with the following setup:
https://viewer.diagrams.net/?tags=%7B%7 ... S6%2FgE%3D
The issue is that i can ping from LAN1 to LAN2, but not the other way arround
The first router passes internett to the switch on port 1 (WAN), and a routing rule is created on the router to route all the 192.168.50.1/24 traffic to the mikrotik switch (192.168.0.33).
The workstation (192.168.50.100) is connected to port 2 on the mikrotik
I can ping 192.168.50.100 from 192.168.0.54 , but not the other way arround.
So if i try to reach any of the services running on the 192.168.50.1/24 network from LAN1, i get an ERR_CONNECTION_RESET.
Do anyone see the where the issue is?
I have tried replacing the router, but does not change anything
confiпg (followed the Mikrotik First Time Configuration guide):
# software id = EB13-GZFG
# model = CRS326-24G-2S+
add name=local
/ip hotspot profile
add name=dhcp_pool0 ranges=192.168.50.2-192.168.50.254
add address-pool=dhcp_pool0 interface=local name=dhcp1
/port
set 0 name=serial0
add bridge=local interface=ether2
add address=192.168.50.1/24 interface=local network=192.168.50.0
/ip dhcp-client
add interface=ether1
add address=192.168.50.0/24 dns-server=192.168.50.1 gateway=192.168.50.1
/system clock
set time-zone-name=REDACTED/REDACTED
/system routerboard settings
set boot-os=router-os
Users browsing this forum: dawdler, rolling and 66 guests
